[intrepid-notify] Intrepid /gpfs1 back up
Andrew Cherry
acherry at mcs.anl.gov
Sat Aug 9 02:07:55 CDT 2008
Intrepid /gpfs1 is back in service.
Andrew Cherry
ALCF Support
On Aug 9, 2008, at 1:47 AM, Andrew Cherry wrote:
> We are encountering problems with /gpfs1 on Intrepid. We have not
> yet identified the cause and are still working the issue, but it may
> not be resolved until the morning. Please avoid submitting any jobs
> that use /gpfs1 until the issue is resolved. In the interim, we
> recommend you use your home directory for job runs.
> I have held any jobs that appear to use /gpfs1, but you may want to
> check yours and ensure I didn't miss one -- I could only identify
> those jobs that have a working directory, command, or command-line
> arguments containing the string "/gpfs1". If you have a job that
> has /gpfs1 hardcoded somewhere in the code itself, I will likely
> have missed it. In that case, we would recommend that you hold your
> job using "qhold <jobid>" until the issues have been resolved.
> Thanks for your patience.
> Andrew Cherry
> ALCF Support
More information about the intrepid-notify
