[intrepid-notify] Monday Maintenance reminder for September 15, 2008
Tisha Stacey
tstacey at alcf.anl.gov
Fri Sep 12 15:31:25 CDT 2008
The Intrepid system will have its regularly scheduled Monday maintenance
period this coming week.
Maintenance starts: 9:00 a.m. US CDT on Monday, September 15, 2008
Expected end: 5:00 p.m. US CDT on Monday, September 15, 2008
During this time:
- no jobs will be run on the system
- there may be disruptions in filesystem access
- there may be disruptions in network access to the login nodes.
During this window, changes will be made to the user environment:
- Network maintenance
- An eFix for the BG/P communication libraries will be installed. A
recompile is required to take advantage of the fixes, but is not
required otherwise. Important changes:
- The default setting for scatterv-via-bcast optimization has
changed. Previously, it was on by default; now you must
explicitly request is by setting DCMF_SCATTERV=B.
- The problem of using less than an entire partition in dual mode,
i.e., booting a midplane and using -np 512, has been partially
addressed. It will still fail when using an odd number of cores.
Using an even number of cores and TXYZ layout will work.
- Details about the efix can be found at
http://wiki.alcf.anl.gov/index.php/Efix_bgp_v1r2m0_013
Mail will be sent when the work has been completed and the machines are
again available for general use. Please send any comments or questions
to support at alcf.anl.gov
Thank you,
The ALCF Support Team
More information about the intrepid-notify
