[intrepid-notify] Re: GPFS issues
Andrew Cherry
acherry at mcs.anl.gov
Thu Sep 25 13:18:05 CDT 2008
FYI, it looks like GPFS began having problems on Intrepid again about
20 minutes ago. We're investigating.
-Andrew
On Sep 25, 2008, at 12:03 PM, Andrew Cherry wrote:
> GPFS appears to be stable again on the Intrepid logins. If you
> encounter further problems logging in, please let us know.
> Andrew Cherry
> ALCF Support
> On Sep 25, 2008, at 11:26 AM, Andrew Cherry wrote:
>> Another update - I've temporarily disabled queueing on intrepid
>> until we've resolved the GPFS issues, so if you notice the queues
>> not moving, that's why.
>> -Andrew
>> On Sep 25, 2008, at 10:58 AM, Andrew Cherry wrote:
>>> Just a quick note to say that the scope of the problem still seems
>>> to be larger than just login5 - we are aware of this and
>>> continuing to work on the problem. We'll let you know when the
>>> situation changes.
>>> -Andrew
>>> On Sep 25, 2008, at 10:16 AM, Andrew Cherry wrote:
>>>> Intrepid users-
>>>> We're encountering some GPFS issues on Intrepid that we're
>>>> working through. At the moment, the situation seems to have
>>>> stabilized with the exception of login5.intrepid. I would like
>>>> to leave this login node as-is until our primary GPFS admin
>>>> arrives later this morning so he can collect more data on the
>>>> situation. If you are currently using login5, or you end up on
>>>> login5, you may want to try again to get a different login node
>>>> (or explicitly log in to one of the others using the full
>>>> hostname, e.g. login1.intrepid.alcf.anl.gov).
>>>> Thanks, and we'll keep you updated. Be aware that we will
>>>> probably need to reboot login5 at some point in the near future.
>>>> Andrew Cherry
>>>> ALCF Support
>>> _______________________________________________
>>> intrepid-notify mailing list
>>> intrepid-notify at alcf.anl.gov
>>> http://lists.alcf.anl.gov/cgi-bin/mailman/listinfo/intrepid-notify
URL: <http://lists.alcf.anl.gov/pipermail/intrepid-notify/attachments/20080925/45f510bf/attachment.htm>
More information about the intrepid-notify
