[intrepid-notify] Re: GPFS issues
Andrew Cherry
acherry at mcs.anl.gov
Thu Sep 25 12:03:54 CDT 2008
GPFS appears to be stable again on the Intrepid logins. If you
encounter further problems logging in, please let us know.
Andrew Cherry
ALCF Support
On Sep 25, 2008, at 11:26 AM, Andrew Cherry wrote:
> Another update - I've temporarily disabled queueing on intrepid
> until we've resolved the GPFS issues, so if you notice the queues
> not moving, that's why.
> -Andrew
> On Sep 25, 2008, at 10:58 AM, Andrew Cherry wrote:
>> Just a quick note to say that the scope of the problem still seems
>> to be larger than just login5 - we are aware of this and continuing
>> to work on the problem. We'll let you know when the situation
>> changes.
>> -Andrew
>> On Sep 25, 2008, at 10:16 AM, Andrew Cherry wrote:
>>> Intrepid users-
>>> We're encountering some GPFS issues on Intrepid that we're working
>>> through. At the moment, the situation seems to have stabilized
>>> with the exception of login5.intrepid. I would like to leave this
>>> login node as-is until our primary GPFS admin arrives later this
>>> morning so he can collect more data on the situation. If you are
>>> currently using login5, or you end up on login5, you may want to
>>> try again to get a different login node (or explicitly log in to
>>> one of the others using the full hostname, e.g.
>>> login1.intrepid.alcf.anl.gov).
>>> Thanks, and we'll keep you updated. Be aware that we will
>>> probably need to reboot login5 at some point in the near future.
>>> Andrew Cherry
>>> ALCF Support
>> intrepid-notify mailing list
>> intrepid-notify at alcf.anl.gov
>> http://lists.alcf.anl.gov/cgi-bin/mailman/listinfo/intrepid-notify
URL: <http://lists.alcf.anl.gov/pipermail/intrepid-notify/attachments/20080925/859957d3/attachment.htm>
More information about the intrepid-notify
