[intrepid-notify] Re: GPFS issues
Andrew Cherry
acherry at mcs.anl.gov
Thu Sep 25 11:26:00 CDT 2008
Another update - I've temporarily disabled queueing on intrepid until
we've resolved the GPFS issues, so if you notice the queues not
moving, that's why.
-Andrew
On Sep 25, 2008, at 10:58 AM, Andrew Cherry wrote:
> Just a quick note to say that the scope of the problem still seems
> to be larger than just login5 - we are aware of this and continuing
> to work on the problem. We'll let you know when the situation
> changes.
> -Andrew
> On Sep 25, 2008, at 10:16 AM, Andrew Cherry wrote:
>> Intrepid users-
>> We're encountering some GPFS issues on Intrepid that we're working
>> through. At the moment, the situation seems to have stabilized
>> with the exception of login5.intrepid. I would like to leave this
>> login node as-is until our primary GPFS admin arrives later this
>> morning so he can collect more data on the situation. If you are
>> currently using login5, or you end up on login5, you may want to
>> try again to get a different login node (or explicitly log in to
>> one of the others using the full hostname, e.g.
>> login1.intrepid.alcf.anl.gov).
>> Thanks, and we'll keep you updated. Be aware that we will probably
>> need to reboot login5 at some point in the near future.
>> Andrew Cherry
>> ALCF Support
> intrepid-notify mailing list
> intrepid-notify at alcf.anl.gov
> http://lists.alcf.anl.gov/cgi-bin/mailman/listinfo/intrepid-notify
URL: <http://lists.alcf.anl.gov/pipermail/intrepid-notify/attachments/20080925/22c5df15/attachment.htm>
More information about the intrepid-notify
