[intrepid-notify] Re: GPFS issues
Andrew Cherry
acherry at alcf.anl.gov
Thu Sep 25 10:58:10 CDT 2008
Just a quick note to say that the scope of the problem still seems to
be larger than just login5 - we are aware of this and continuing to
work on the problem. We'll let you know when the situation changes.
-Andrew
On Sep 25, 2008, at 10:16 AM, Andrew Cherry wrote:
> Intrepid users-
> We're encountering some GPFS issues on Intrepid that we're working
> through. At the moment, the situation seems to have stabilized with
> the exception of login5.intrepid. I would like to leave this login
> node as-is until our primary GPFS admin arrives later this morning
> so he can collect more data on the situation. If you are currently
> using login5, or you end up on login5, you may want to try again to
> get a different login node (or explicitly log in to one of the
> others using the full hostname, e.g. login1.intrepid.alcf.anl.gov).
> Thanks, and we'll keep you updated. Be aware that we will probably
> need to reboot login5 at some point in the near future.
> Andrew Cherry
> ALCF Support
More information about the intrepid-notify
