[Llvm-bgq-discuss] november patches
Michael Blocksome blocksom at us.ibm.com
Wed Dec 12 14:06:19 CST 2012
Hal,
Thanks for the help. I pulled the llvm source from the revision that your
most recently posted patches are diffed against, applied the patches,
configured and compiled.  Unfortunately, I'm getting some strange link
errors that I can't seem to eliminate.  Do you have any suggestions for
different configure options I should try? Below is my current configure
command:
bgqfen6 ~/development/llvm-build> head config.log
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by LLVM configure 3.2svn, which was
generated by GNU Autoconf 2.60.  Invocation command line was
  $ ../llvm/configure --prefix=/bghome/blocksom/development/llvm-install
--with-gcc-toolchain=/bgsys/drivers/ppcfloor/gnu-linux
## Platform. ##
Michael Blocksome
Blue Gene Messaging
To:     Michael Blocksome/Rochester/IBM at IBMUS,
Cc:     llvm-bgq-discuss at lists.alcf.anl.gov
Date:   12/06/2012 12:58 PM
Subject:        Re: [Llvm-bgq-discuss] november patches
Michael,
It would have been r167420. At this point, you might as well use the 3.2
release branch. I can rebase the patches for you as necessary. Also, FWIW,
I'm very close to making another internal release candidate based on the
current trunk version. If that happens next week, I'll probably just post
patches for that.
Thanks again,
Hal
----- Original Message -----
> From: "Michael Blocksome" <blocksom at us.ibm.com>
> To: "Hal Finkel" <hfinkel at anl.gov>
> Sent: Thursday, December 6, 2012 12:50:20 PM
> Hal,
> Do you know what revision (or release) of llvm/clang the june patches
> were made against? If so I could get llvm/clag working from that
> base until you have time to update the code/documentation.
> Thanks,
> Michael Blocksome
> Blue Gene Messaging
> From: Hal Finkel <hfinkel at anl.gov>
> Date: 12/06/2012 11:22 AM
> Michael,
> I'll need to post updated patches (along with new wrapper scripts,
> etc.). Thanks for the reminder. I'll try to get this done by next
> week.
> Thanks again,
> Hal
> > To: llvm-bgq-discuss at lists.alcf.anl.gov
> > Sent: Thursday, December 6, 2012 11:05:14 AM
> > Subject: [Llvm-bgq-discuss] november patches
> > The llvm-bgq trac page (
> > https://trac.alcf.anl.gov/projects/llvm-bgq/
> > ) does not have the LLVM and clang patches for your most recent
> > release, "r167420-20121105".
> > How can I get access to these patches and to what revision of the
> > LLVM and clang svn repositories do I need to patch?
> > Thanks,
> > Michael Blocksome
> > Blue Gene Messaging
> > _______________________________________________
> > llvm-bgq-discuss mailing list
> > https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> Hal Finkel
> Postdoctoral Appointee
> Leadership Computing Facility
> Argonne National Laboratory
Hal Finkel
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20121212/b8e40801/attachment.html>
More information about the llvm-bgq-discuss mailing list
