[Llvm-bgq-discuss] november patches
Hal Finkel hfinkel at anl.gov
Wed Dec 12 14:58:05 CST 2012
Michael,
I've not tried using --with-gcc-toolchain when configuring; I don't know if that is causing a problem. Also, I generally build like this:
make -j 8 ENABLE_OPTIMIZED=1 OPTIMIZE_OPTION=-O2 EXTRA_OPTIONS=-mminimal-toc
I'm aiming to have a new set of patches for everyone by the end of the week.
 -Hal
----- Original Message -----
> Hal,
> Thanks for the help. I pulled the llvm source from the revision that
> your most recently posted patches are diffed against, applied the
> patches, configured and compiled. Unfortunately, I'm getting some
> strange link errors that I can't seem to eliminate. Do you have any
> suggestions for different configure options I should try? Below is my
> current configure command:
> bgqfen6 ~/development/llvm-build> head config.log
> This file contains any messages produced by compilers while
> running configure, to aid debugging if configure makes a mistake.
> It was created by LLVM configure 3.2svn, which was
> generated by GNU Autoconf 2.60. Invocation command line was
> $ ../llvm/configure --prefix=/bghome/blocksom/development/llvm-install
> --with-gcc-toolchain=/bgsys/drivers/ppcfloor/gnu-linux
> ## Platform. ##
> Thanks,
> Michael Blocksome
> Blue Gene Messaging
> blocksom at us.ibm.com
> From: Hal Finkel <hfinkel at anl.gov>
> To: Michael Blocksome/Rochester/IBM at IBMUS,
> Cc: llvm-bgq-discuss at lists.alcf.anl.gov
> Date: 12/06/2012 12:58 PM
> Subject: Re: [Llvm-bgq-discuss] november patches
> Michael,
> It would have been r167420. At this point, you might as well use the
> 3.2 release branch. I can rebase the patches for you as necessary.
> Also, FWIW, I'm very close to making another internal release
> candidate based on the current trunk version. If that happens next
> week, I'll probably just post patches for that.
> Thanks again,
> Hal
> > From: "Michael Blocksome" <blocksom at us.ibm.com>
> > To: "Hal Finkel" <hfinkel at anl.gov>
> > Sent: Thursday, December 6, 2012 12:50:20 PM
> > Hal,
> > Do you know what revision (or release) of llvm/clang the june
> > patches
> > were made against? If so I could get llvm/clag working from that
> > base until you have time to update the code/documentation.
> > Thanks,
> > Michael Blocksome
> > Blue Gene Messaging
> > Date: 12/06/2012 11:22 AM
> > Michael,
> > I'll need to post updated patches (along with new wrapper scripts,
> > etc.). Thanks for the reminder. I'll try to get this done by next
> > week.
> > Thanks again,
> > Hal
> > > To: llvm-bgq-discuss at lists.alcf.anl.gov
> > > Sent: Thursday, December 6, 2012 11:05:14 AM
> > > Subject: [Llvm-bgq-discuss] november patches
> > > The llvm-bgq trac page (
> > > https://trac.alcf.anl.gov/projects/llvm-bgq/
> > > ) does not have the LLVM and clang patches for your most recent
> > > release, "r167420-20121105".
> > > How can I get access to these patches and to what revision of the
> > > LLVM and clang svn repositories do I need to patch?
> > > Thanks,
> > > Michael Blocksome
> > > Blue Gene Messaging
> > > _______________________________________________
> > > llvm-bgq-discuss mailing list
> > > https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> > Hal Finkel
> > Postdoctoral Appointee
> > Leadership Computing Facility
> > Argonne National Laboratory
> Hal Finkel
Hal Finkel
More information about the llvm-bgq-discuss mailing list
