[Llvm-bgq-discuss] november patches
Hal Finkel
hfinkel at anl.gov
Thu Dec 13 19:15:11 CST 2012
Michael, et al.,
I've switched the current llvm install on vesta to r170143-20121213; the website is down right now, so I'll post the patches once it comes back (and then I'll send out a real e-mail announcement). In the mean time, I've attached the patches and the corresponding updated bgclang wrapper script.
Please try these instead of using the ones currently on the web site. *Many* bugs have been fixed (and the performance should be better as well).
-Hal
----- Original Message -----
> From: "Hal Finkel" <hfinkel at anl.gov>
> To: "Michael Blocksome" <blocksom at us.ibm.com>
> Cc: llvm-bgq-discuss at lists.alcf.anl.gov
> Sent: Wednesday, December 12, 2012 2:58:05 PM
> Subject: Re: [Llvm-bgq-discuss] november patches
> Michael,
> I've not tried using --with-gcc-toolchain when configuring; I don't
> know if that is causing a problem. Also, I generally build like
> this:
> make -j 8 ENABLE_OPTIMIZED=1 OPTIMIZE_OPTION=-O2
> EXTRA_OPTIONS=-mminimal-toc
> I'm aiming to have a new set of patches for everyone by the end of
> the week.
> -Hal
> > Hal,
> > Thanks for the help. I pulled the llvm source from the revision
> > that
> > your most recently posted patches are diffed against, applied the
> > patches, configured and compiled. Unfortunately, I'm getting some
> > strange link errors that I can't seem to eliminate. Do you have any
> > suggestions for different configure options I should try? Below is
> > my
> > current configure command:
> > bgqfen6 ~/development/llvm-build> head config.log
> > This file contains any messages produced by compilers while
> > running configure, to aid debugging if configure makes a mistake.
> > It was created by LLVM configure 3.2svn, which was
> > generated by GNU Autoconf 2.60. Invocation command line was
> > $ ../llvm/configure
> > --prefix=/bghome/blocksom/development/llvm-install
> > --with-gcc-toolchain=/bgsys/drivers/ppcfloor/gnu-linux
> > ## Platform. ##
> > Thanks,
> > Michael Blocksome
> > Blue Gene Messaging
> > From: Hal Finkel <hfinkel at anl.gov>
> > To: Michael Blocksome/Rochester/IBM at IBMUS,
> > Date: 12/06/2012 12:58 PM
> > Michael,
> > It would have been r167420. At this point, you might as well use
> > the
> > 3.2 release branch. I can rebase the patches for you as necessary.
> > Also, FWIW, I'm very close to making another internal release
> > candidate based on the current trunk version. If that happens next
> > week, I'll probably just post patches for that.
> > Thanks again,
> > Hal
> > > From: "Michael Blocksome" <blocksom at us.ibm.com>
> > > To: "Hal Finkel" <hfinkel at anl.gov>
> > > Sent: Thursday, December 6, 2012 12:50:20 PM
> > > Hal,
> > > Do you know what revision (or release) of llvm/clang the june
> > > patches
> > > were made against? If so I could get llvm/clag working from that
> > > base until you have time to update the code/documentation.
> > > Thanks,
> > > Michael Blocksome
> > > Blue Gene Messaging
> > > Date: 12/06/2012 11:22 AM
> > > Michael,
> > > I'll need to post updated patches (along with new wrapper
> > > scripts,
> > > etc.). Thanks for the reminder. I'll try to get this done by next
> > > week.
> > > Thanks again,
> > > Hal
> > > > To: llvm-bgq-discuss at lists.alcf.anl.gov
> > > > Sent: Thursday, December 6, 2012 11:05:14 AM
> > > > Subject: [Llvm-bgq-discuss] november patches
> > > > The llvm-bgq trac page (
> > > > https://trac.alcf.anl.gov/projects/llvm-bgq/
> > > > ) does not have the LLVM and clang patches for your most recent
> > > > release, "r167420-20121105".
> > > > How can I get access to these patches and to what revision of
> > > > the
> > > > LLVM and clang svn repositories do I need to patch?
> > > > Thanks,
> > > > Michael Blocksome
> > > > Blue Gene Messaging
> > > > _______________________________________________
> > > > llvm-bgq-discuss mailing list
> > > > https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> > > Hal Finkel
> > > Postdoctoral Appointee
> > > Leadership Computing Facility
> > > Argonne National Laboratory
> > Hal Finkel
> Hal Finkel
Hal Finkel
Type: text/x-patch
Desc: not available
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20121213/bde5ec2c/attachment-0003.bin>
Type: text/x-patch
Desc: not available
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20121213/bde5ec2c/attachment-0004.bin>
Type: application/x-shellscript
Desc: not available
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20121213/bde5ec2c/attachment-0005.bin>
More information about the llvm-bgq-discuss
