[Llvm-bgq-discuss] november patches
Michael Blocksome blocksom at us.ibm.com
Fri Dec 14 11:40:55 CST 2012
Hal,
Thanks for the update.  I've compiled llvm/clang locally with your patches
and ran some "hello world" programs on our bgq hardware successfully.
Works great!
Michael Blocksome
Blue Gene Messaging
To:     Michael Blocksome/Rochester/IBM at IBMUS,
Cc:     llvm-bgq-discuss at lists.alcf.anl.gov
Date:   12/13/2012 07:19 PM
Subject:        Re: [Llvm-bgq-discuss] november patches
Michael, et al.,
I've switched the current llvm install on vesta to r170143-20121213; the
website is down right now, so I'll post the patches once it comes back
(and then I'll send out a real e-mail announcement). In the mean time,
I've attached the patches and the corresponding updated bgclang wrapper
script.
Please try these instead of using the ones currently on the web site.
*Many* bugs have been fixed (and the performance should be better as
well).
 -Hal
----- Original Message -----
> From: "Hal Finkel" <hfinkel at anl.gov>
> To: "Michael Blocksome" <blocksom at us.ibm.com>
> Sent: Wednesday, December 12, 2012 2:58:05 PM
> Michael,
> I've not tried using --with-gcc-toolchain when configuring; I don't
> know if that is causing a problem. Also, I generally build like
> this:
> make -j 8 ENABLE_OPTIMIZED=1 OPTIMIZE_OPTION=-O2
> EXTRA_OPTIONS=-mminimal-toc
> I'm aiming to have a new set of patches for everyone by the end of
> the week.
>  -Hal
> > Hal,
> > Thanks for the help. I pulled the llvm source from the revision
> > that
> > your most recently posted patches are diffed against, applied the
> > patches, configured and compiled. Unfortunately, I'm getting some
> > strange link errors that I can't seem to eliminate. Do you have any
> > suggestions for different configure options I should try? Below is
> > my
> > current configure command:
> > bgqfen6 ~/development/llvm-build> head config.log
> > This file contains any messages produced by compilers while
> > running configure, to aid debugging if configure makes a mistake.
> > It was created by LLVM configure 3.2svn, which was
> > generated by GNU Autoconf 2.60. Invocation command line was
> > $ ../llvm/configure
> > --prefix=/bghome/blocksom/development/llvm-install
> > --with-gcc-toolchain=/bgsys/drivers/ppcfloor/gnu-linux
> > ## Platform. ##
> > Thanks,
> > Michael Blocksome
> > Blue Gene Messaging
> > From: Hal Finkel <hfinkel at anl.gov>
> > Date: 12/06/2012 12:58 PM
> > Michael,
> > It would have been r167420. At this point, you might as well use
> > the
> > 3.2 release branch. I can rebase the patches for you as necessary.
> > Also, FWIW, I'm very close to making another internal release
> > candidate based on the current trunk version. If that happens next
> > week, I'll probably just post patches for that.
> > Thanks again,
> > Hal
> > > From: "Michael Blocksome" <blocksom at us.ibm.com>
> > > To: "Hal Finkel" <hfinkel at anl.gov>
> > > Sent: Thursday, December 6, 2012 12:50:20 PM
> > > Hal,
> > > Do you know what revision (or release) of llvm/clang the june
> > > patches
> > > were made against? If so I could get llvm/clag working from that
> > > base until you have time to update the code/documentation.
> > > Thanks,
> > > Michael Blocksome
> > > Blue Gene Messaging
> > > Date: 12/06/2012 11:22 AM
> > > Michael,
> > > I'll need to post updated patches (along with new wrapper
> > > scripts,
> > > etc.). Thanks for the reminder. I'll try to get this done by next
> > > week.
> > > Thanks again,
> > > Hal
> > > > To: llvm-bgq-discuss at lists.alcf.anl.gov
> > > > Sent: Thursday, December 6, 2012 11:05:14 AM
> > > > Subject: [Llvm-bgq-discuss] november patches
> > > > The llvm-bgq trac page (
> > > > https://trac.alcf.anl.gov/projects/llvm-bgq/
> > > > ) does not have the LLVM and clang patches for your most recent
> > > > release, "r167420-20121105".
> > > > How can I get access to these patches and to what revision of
> > > > the
> > > > LLVM and clang svn repositories do I need to patch?
> > > > Thanks,
> > > > Michael Blocksome
> > > > Blue Gene Messaging
> > > > _______________________________________________
> > > > llvm-bgq-discuss mailing list
> > > > https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> > > Hal Finkel
> > > Postdoctoral Appointee
> > > Leadership Computing Facility
> > > Argonne National Laboratory
> > Hal Finkel
> Hal Finkel
Hal Finkel
[attachment "llvm-bgq-r170143-20121213.patch" deleted by Michael
Blocksome/Rochester/IBM] [attachment "clang-bgq-r170143-20121213.patch"
deleted by Michael Blocksome/Rochester/IBM] [attachment "bgclang-20121213"
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20121214/6695045d/attachment.html>
More information about the llvm-bgq-discuss mailing list
