[Llvm-bgq-discuss] clang ICE
Michael Blocksome blocksom at us.ibm.com
Mon Dec 17 14:29:24 CST 2012
I've encountered an ICE with clang and was wondering if someone on the
list could recreate the problem?  I thought I'd start here instead of
submitting a clang bug report since I'm using the provided patches and
compile script. I'm not sure if the problem is with the patched llvm/clang
or if it is in the base source.
        bgclang-20121213
        clang-bgq-r170143-20121213.patch
        llvm-bgq-r170143-20121213.patch
I've pulled out the majority of the junk around the failure and have it
down to a few files and a clang command (whittled down from -v output of
the entire build). To recreate, just edit and run the 'clang_ice.sh' file.
Michael Blocksome
Blue Gene Messaging
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20121217/c3043611/attachment-0001.html>
Desc: not available
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20121217/c3043611/attachment-0001.obj>
More information about the llvm-bgq-discuss mailing list
