[Llvm-bgq-discuss] bgclang r188569-20130816 on vesta/mira
Hal Finkel
hfinkel at anl.gov
Tue Aug 20 14:58:36 CDT 2013
Hi again,
I've updated the current install again. The change is only to the bgclang wrapper script; we needed to do a better job of disabling the new SLP vectorizer (I'm observing miscompiles).
[begin background]
LLVM currently has two SLP (superword-level parallelism, a.k.a. basic block) autovectorization passes. The first, which we now call the "aggressive" pass, was authored by yours truly, and we've had it for a while now. There is also a new SLP vectorizer, which should be less compile-time intensive, but currently still seems to have some problems.
[end background]
A -v3 archive is on the trac page for those maintaining independent installs.
-Hal
----- Original Message -----
> Hello everyone,
> The current install has just been patched to fix a small bug dealing
> with explicitly passing vector2double variables as function
> parameters.
> A -v2 archive is on the trac page for those maintaining independent
> installs.
> -Hal
> > Hello everyone,
> > I've updated the install on vesta/mira to r188569-20130816. This
> > grabs an upstream bugfix and a local fix (to a problem reported by
> > Jeff when compiling GSL).
> > As usual, for those maintaining independent installs, an updated
> > archive is on: http://trac.alcf.anl.gov/projects/llvm-bgq
> > -Hal
> > Hal Finkel
> > Assistant Computational Scientist
> > Leadership Computing Facility
> > Argonne National Laboratory
> > _______________________________________________
> > llvm-bgq-discuss mailing list
> > llvm-bgq-discuss at lists.alcf.anl.gov
> > https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> Hal Finkel
Hal Finkel
More information about the llvm-bgq-discuss
