[Llvm-bgq-discuss] pulling in mpi using clang
Jeff Hammond
jhammond at alcf.anl.gov
Fri Feb 1 08:39:57 CST 2013
No, I have never explored this. If you use the script I put on
https://wiki.alcf.anl.gov/parts/index.php/MPICH2_on_Blue_Gene/Q#Building_BGQ-MPI_from_source
you can trivially build MPICH-BGQ with LLVM (at least V1R1M2) and see
how it does.
Jeff
On Fri, Feb 1, 2013 at 11:34 PM, Michael Blocksome <blocksom at us.ibm.com> wrote:
> Do you guys have any benchmark numbers for the bgclang version of mpich -
> and how it compares to the bgsys xl and bgsys gcc versions of mpich? Just
> curious ...
> Michael Blocksome
> Blue Gene Messaging
> From: Jeff Hammond <jhammond at alcf.anl.gov>
> To: Geoffrey Irving <irving at naml.us>,
> Cc: llvm-bgq-discuss at lists.alcf.anl.gov
> Date: 02/01/2013 12:22 AM
> Subject: Re: [Llvm-bgq-discuss] pulling in mpi using clang
> Sent by: llvm-bgq-discuss-bounces at lists.alcf.anl.gov
> ________________________________
>> What's the proper way to get mpi when using
>> /home/projects/llvm/current/bin/bgclang++?
> I thought Hal made wrappers at some point. Maybe on another machine.
>> Previously, I stole the flags from the gcc mpi wrapper (I unfortunately do
>> not remember how I
>> did this), and then manually specifiied
> You can use mpicxx wrapper with MPICH_CXX=bgclang++ instead to get the
> same thing with less typing.
>> -I/bgsys/drivers/V1R1M2/ppc64/comm/sys/include
>> -I/bgsys/drivers/V1R1M2/ppc64/spi/include
>> -I/bgsys/drivers/V1R1M2/ppc64/spi/include/kernel/cnk
>> -I/bgsys/drivers/V1R1M2/ppc64/comm/gcc/include
>> -Wl,-rpath=/bgsys/drivers/V1R1M2/ppc64/comm/gcc/lib
>> -Wl,-rpath=/bgsys/drivers/V1R1M2/ppc64/comm/sys/lib
>> -Wl,-rpath=/bgsys/drivers/V1R1M2/ppc64/spi/lib
>> -L/bgsys/drivers/V1R1M2/ppc64/comm/gcc/lib
>> -L/bgsys/drivers/V1R1M2/ppc64/comm/sys/lib
>> -L/bgsys/drivers/V1R1M2/ppc64/spi/lib -lmpich -lopa -lmpl -lrt -ldl
>> -lpami -lSPI -lSPI_cnk -lpthread
>> This seems fairly sketchy, so I'd like to do it the right way if such
>> exists, especially if the driver versions are going to change soon.
> I don't think it is sketchy. It's what I've been doing for all my
> LLVM codes. LAMMPS (C++ molecular dynamics code using MPI C
> interface) had no issues with this recipe.
>> Are there wrapper compilers set up?
> As noted above, I don't know.
> I can build you a bona fide LLVM MPICH though if you think it would
> help. I did this a long time ago and just need to update it.
>> If I do the above manual way, and qsub a job, it errors out during launch
>> with
>> VST-20400-31511-32:14558:ibm.runjob.client.Job: Load failed on
>> Q02-I4-J04: Application executable ELF header contains invalid value,
>> errno 8 Exec format error
>> It's possible this is unrelated, of course.
> Looks like an LLVM-related issue but not an MPI one, at least not directly.
> Jeff
> Jeff Hammond
> Argonne Leadership Computing Facility
> University of Chicago Computation Institute
> jhammond at alcf.anl.gov / (630) 252-5381
> http://www.linkedin.com/in/jeffhammond
> https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
> llvm-bgq-discuss mailing list
> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
Jeff Hammond
More information about the llvm-bgq-discuss
