[Llvm-bgq-discuss] pulling in mpi using clang
Michael Blocksome
blocksom at us.ibm.com
Fri Feb 1 08:34:42 CST 2013
Do you guys have any benchmark numbers for the bgclang version of mpich -
and how it compares to the bgsys xl and bgsys gcc versions of mpich? Just
curious ...
Michael Blocksome
Blue Gene Messaging
To: Geoffrey Irving <irving at naml.us>,
Cc: llvm-bgq-discuss at lists.alcf.anl.gov
Date: 02/01/2013 12:22 AM
Subject: Re: [Llvm-bgq-discuss] pulling in mpi using clang
Sent by: llvm-bgq-discuss-bounces at lists.alcf.anl.gov
> What's the proper way to get mpi when using
/home/projects/llvm/current/bin/bgclang++?
I thought Hal made wrappers at some point. Maybe on another machine.
> Previously, I stole the flags from the gcc mpi wrapper (I unfortunately
do not remember how I
> did this), and then manually specifiied
You can use mpicxx wrapper with MPICH_CXX=bgclang++ instead to get the
same thing with less typing.
> -I/bgsys/drivers/V1R1M2/ppc64/comm/sys/include
> -I/bgsys/drivers/V1R1M2/ppc64/spi/include
> -I/bgsys/drivers/V1R1M2/ppc64/spi/include/kernel/cnk
> -I/bgsys/drivers/V1R1M2/ppc64/comm/gcc/include
> -Wl,-rpath=/bgsys/drivers/V1R1M2/ppc64/comm/gcc/lib
> -Wl,-rpath=/bgsys/drivers/V1R1M2/ppc64/comm/sys/lib
> -Wl,-rpath=/bgsys/drivers/V1R1M2/ppc64/spi/lib
> -L/bgsys/drivers/V1R1M2/ppc64/comm/gcc/lib
> -L/bgsys/drivers/V1R1M2/ppc64/comm/sys/lib
> -L/bgsys/drivers/V1R1M2/ppc64/spi/lib -lmpich -lopa -lmpl -lrt -ldl
> -lpami -lSPI -lSPI_cnk -lpthread
> This seems fairly sketchy, so I'd like to do it the right way if such
exists, especially if the driver versions are going to change soon.
I don't think it is sketchy. It's what I've been doing for all my
LLVM codes. LAMMPS (C++ molecular dynamics code using MPI C
interface) had no issues with this recipe.
> Are there wrapper compilers set up?
As noted above, I don't know.
I can build you a bona fide LLVM MPICH though if you think it would
help. I did this a long time ago and just need to update it.
> If I do the above manual way, and qsub a job, it errors out during
launch with
> VST-20400-31511-32:14558:ibm.runjob.client.Job: Load failed on
> Q02-I4-J04: Application executable ELF header contains invalid value,
> errno 8 Exec format error
> It's possible this is unrelated, of course.
Looks like an LLVM-related issue but not an MPI one, at least not
directly.
Jeff
Jeff Hammond
Argonne Leadership Computing Facility
University of Chicago Computation Institute
jhammond at alcf.anl.gov / (630) 252-5381
http://www.linkedin.com/in/jeffhammond
https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
llvm-bgq-discuss mailing list
https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20130201/df948bc7/attachment-0001.html>
More information about the llvm-bgq-discuss
