[Llvm-bgq-discuss] Details behind MPI wrapper for bgclang++
Hal Finkel
hfinkel at anl.gov
Thu Feb 28 18:08:59 CST 2013
Jack,
What Jeff said is correct. Jeff, I did not specifically update the wrapper scripts after the V1R2 transition. Is there anything that I need to do for that?
Also, Jack, are you using the mpic++ (with -std=c++11) wrapper or the mpic++11 wrapper?
-Hal
----- Original Message -----
> From: "Jeff Hammond" <jhammond at alcf.anl.gov>
> To: "Jack Poulson" <jack.poulson at gmail.com>
> Cc: llvm-bgq-discuss at lists.alcf.anl.gov
> Sent: Thursday, February 28, 2013 5:59:08 PM
> Subject: Re: [Llvm-bgq-discuss] Details behind MPI wrapper for bgclang++
> IBM does not provide MPI builds as part of the driver because they do
> not - and are not required to - provide LLVM builds of MPI.
> ALCF can provide /home/projects/pami/llvm/mpi.... if you want an MPI
> build using LLVM. I will do this next week during MiraCon as part of
> building MPICH2 1.5 + IBM patches from source.
> Best,
> Jeff
> On Thu, Feb 28, 2013 at 6:56 PM, Jack Poulson
> <jack.poulson at gmail.com> wrote:
> > Hello All,
> > I am trying to run a C++11 code on BGQ and have been running into
> > strange
> > sporadic segfaults with non-helpful stack traces. I started looking
> > through
> > the details of the driver
> > /home/projects/llvm/mpi/clang/bin/mpicxx and was
> > surprised by the 31st line:
> > prefix=/bgsys/drivers/ppcfloor/comm/gcc
> > When I look in the /bgsys/drivers/ppcfloor/comm folder, I notice
> > that there
> > are directories for gcc and xl, but none for Clang. Is there some
> > clear
> > explanation for this?
> > Thanks!
> > Jack
> > _______________________________________________
> > llvm-bgq-discuss mailing list
> > https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> Jeff Hammond
> Argonne Leadership Computing Facility
> University of Chicago Computation Institute
> jhammond at alcf.anl.gov / (630) 252-5381
> http://www.linkedin.com/in/jeffhammond
> https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
More information about the llvm-bgq-discuss
