[Llvm-bgq-discuss] Details behind MPI wrapper for bgclang++
Jack Poulson
jack.poulson at gmail.com
Thu Feb 28 18:12:21 CST 2013
Hi Hal,
As far as I can tell, there are only two distinct wrappers in the
/home/projects/llvm/mpi/clang/bin folder, mpicc and mpicxx, and all of the
others are simply symlinks to them. Is it possible that I am
misunderstanding?
I am using the mpicxx wrapper.
Jack
On Thu, Feb 28, 2013 at 4:08 PM, Hal Finkel <hfinkel at anl.gov> wrote:
> Jack,
> What Jeff said is correct. Jeff, I did not specifically update the wrapper
> scripts after the V1R2 transition. Is there anything that I need to do for
> that?
> Also, Jack, are you using the mpic++ (with -std=c++11) wrapper or the
> mpic++11 wrapper?
> -Hal
> > From: "Jeff Hammond" <jhammond at alcf.anl.gov>
> > To: "Jack Poulson" <jack.poulson at gmail.com>
> > Cc: llvm-bgq-discuss at lists.alcf.anl.gov
> > Sent: Thursday, February 28, 2013 5:59:08 PM
> > Subject: Re: [Llvm-bgq-discuss] Details behind MPI wrapper for bgclang++
> > IBM does not provide MPI builds as part of the driver because they do
> > not - and are not required to - provide LLVM builds of MPI.
> > ALCF can provide /home/projects/pami/llvm/mpi.... if you want an MPI
> > build using LLVM. I will do this next week during MiraCon as part of
> > building MPICH2 1.5 + IBM patches from source.
> > Best,
> > Jeff
> > On Thu, Feb 28, 2013 at 6:56 PM, Jack Poulson
> > <jack.poulson at gmail.com> wrote:
> > > Hello All,
> > > I am trying to run a C++11 code on BGQ and have been running into
> > > strange
> > > sporadic segfaults with non-helpful stack traces. I started looking
> > > through
> > > the details of the driver
> > > /home/projects/llvm/mpi/clang/bin/mpicxx and was
> > > surprised by the 31st line:
> > > prefix=/bgsys/drivers/ppcfloor/comm/gcc
> > > When I look in the /bgsys/drivers/ppcfloor/comm folder, I notice
> > > that there
> > > are directories for gcc and xl, but none for Clang. Is there some
> > > clear
> > > explanation for this?
> > > Thanks!
> > > Jack
> > > _______________________________________________
> > > llvm-bgq-discuss mailing list
> > > https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> > Jeff Hammond
> > Argonne Leadership Computing Facility
> > University of Chicago Computation Institute
> > jhammond at alcf.anl.gov / (630) 252-5381
> > http://www.linkedin.com/in/jeffhammond
> > https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20130228/74f0e9a4/attachment.html>
More information about the llvm-bgq-discuss
