[Llvm-bgq-discuss] cnk syscalls
Michael Blocksome
blocksom at us.ibm.com
Wed Jan 2 12:17:37 CST 2013
All,
I've encountered an ICE with clang built from the recent updates (thanks!)
when I attempt to use certain CNK syscalls. Has anyone else seen this? Is
there a workaround?
Here's my code and the clang output:
.../test> cat personality_ice.cc
#include <kernel/location.h>
int main ()
Personality_t personality;
Kernel_GetPersonality(&personality, sizeof(Personality_t));
return 0;
.../test> /bghome/blocksom/development/llvm/bgclang++ -ferror-limit=10
-I../include -I /bgsys/drivers/ppcfloor -I
/bgsys/drivers/ppcfloor/spi/include -I
/bgsys/drivers/ppcfloor/spi/include/kernel/cnk -std=c++11 -stdlib=libc++
-fno-exceptions -v -c personality_ice.cc -o personality_ice.o
clang version 3.3 (trunk 170456)
Target: powerpc64-bgq-linux
Thread model: posix
"/bghome/blocksom/development/llvm/install/bin/clang" -cc1 -triple
powerpc64-bgq-linux -S -disable-free -main-file-name personality_ice.cc
-static-define -mrelocation-model static -mdisable-fp-elim -fmath-errno
-ffp-contract=fast -mconstructor-aliases -target-cpu a2q
-target-linker-version 2.20.51.0.2 -momit-leaf-frame-pointer -v
-coverage-file /tmp/personality_ice-m3wqVS.s -resource-dir
/bghome/blocksom/development/llvm/install/bin/../lib/clang/3.3 -I
/bgsys/drivers/ppcfloor/spi/include/kernel/cnk -fmodule-cache-path
/var/tmp/clang-module-cache -internal-isystem /usr/include/c++/v1
-internal-isystem /usr/local/include -internal-isystem
/bghome/blocksom/development/llvm/install/bin/../lib/clang/3.3/include
-internal-externc-isystem /include -internal-externc-isystem /usr/include
-std=c++11 -fdeprecated-macro -fno-dwarf-directory-asm
-fdebug-compilation-dir /bghome/blocksom/development/boost-pami/next/test
-ferror-limit 10 -fmessage-length 231 -mstackrealign -fno-signed-char
-fobjc-runtime=gcc -fdiagnostics-show-option -fcolor-diagnostics -isystem
/bghome/blocksom/development/llvm/install/libc++/include -isystem
/bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/include/c++/4.4.6
-isystem
/bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/include/c++/4.4.6/powerpc64-bgq-linux
-isystem /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/sys-include
-mllvm -enable-misched -mllvm -enable-aa-sched-mi -mllvm -ilp-window=0 -o
/tmp/personality_ice-m3wqVS.s -x c++ personality_ice.cc
clang -cc1 version 3.3 based upon LLVM 3.3svn default target
powerpc64-unknown-linux-gnu
ignoring nonexistent directory "/usr/include/c++/v1"
ignoring nonexistent directory "/include"
#include "..." search starts here:
#include <...> search starts here:
../include
/usr/local/include
/usr/include
End of search list.
Instruction uses an allocated register
UNREACHABLE executed at
/bghome/blocksom/development/llvm/src/lib/CodeGen/RegAllocFast.cpp:351!
0 clang 0x0000000011f55b1c
1 clang 0x0000000011f56924
2 0x00000fff962e0418 __kernel_sigtramp_rt64 + 0
3 libc.so.6 0x00000080dbd86ef8 abort + 18446744073708064168
4 clang 0x0000000011f38df4 llvm::llvm_unreachable_internal(char
const*, char const*, unsigned int) + 18446744073696340212
5 clang 0x00000000118fa8c4
6 clang 0x00000000118fb77c
7 clang 0x000000001189498c
llvm::MachineFunctionPass::runOnFunction(llvm::Function&) +
18446744073689552652
8 clang 0x0000000011edaa98
llvm::FPPassManager::runOnFunction(llvm::Function&) + 18446744073695968280
9 clang 0x0000000011edabdc
llvm::FPPassManager::runOnModule(llvm::Module&) + 18446744073695968588
10 clang 0x0000000011eda60c
llvm::MPPassManager::runOnModule(llvm::Module&) + 18446744073695967132
11 clang 0x0000000011edbf64 llvm::PassManagerImpl::run(llvm::Module&)
+ 18446744073695973428
12 clang 0x0000000011edc074 llvm::PassManager::run(llvm::Module&) +
18446744073695973684
13 clang 0x000000001044851c
clang::EmitBackendOutput(clang::DiagnosticsEngine&, clang::CodeGenOptions
const&, clang::TargetOptions const&, clang::LangOptions const&,
llvm::Module*, clang::BackendAction, llvm::raw_ostream*) +
18446744073668788412
14 clang 0x00000000104453f4
15 clang 0x00000000105db3d0 clang::ParseAST(clang::Sema&, bool, bool)
+ 18446744073670399680
16 clang 0x00000000102a0b50 clang::ASTFrontendAction::ExecuteAction()
+ 18446744073667099648
17 clang 0x0000000010443028 clang::CodeGenAction::ExecuteAction() +
18446744073668767224
18 clang 0x00000000102a1024 clang::FrontendAction::Execute() +
18446744073667100756
19 clang 0x000000001027ed64
clang::CompilerInstance::ExecuteAction(clang::FrontendAction&) +
18446744073666962340
20 clang 0x000000001025f704
clang::ExecuteCompilerInvocation(clang::CompilerInstance*) +
18446744073666839428
21 clang 0x0000000010255998 cc1_main(char const**, char const**, char
const*, void*) + 18446744073666799576
22 clang 0x000000001025daf0 main + 18446744073666832256
23 libc.so.6 0x00000080dbd6bcf8
24 libc.so.6 0x00000080dbd6bef0 __libc_start_main + 18446744073707958816
Stack dump:
0. Program arguments:
/bghome/blocksom/development/llvm/install/bin/clang -cc1 -triple
-isystem
1. <eof> parser at end of file
2. Code generation
3. Running pass 'Function Pass Manager' on module
'personality_ice.cc'.
4. Running pass 'Fast Register Allocator' on function '@main'
clang: error: unable to execute command: Aborted (core dumped)
clang: error: clang frontend command failed due to signal (use -v to see
invocation)
Thread model: posix
clang: note: diagnostic msg: PLEASE submit a bug report to
http://llvm.org/bugs/ and include the crash backtrace, preprocessed
source, and associated run script.
PLEASE ATTACH THE FOLLOWING FILES TO THE BUG REPORT:
Preprocessed source(s) and associated run script(s) are located at:
clang: note: diagnostic msg: /tmp/personality_ice-hApwmA.cpp
clang: note: diagnostic msg: /tmp/personality_ice-hApwmA.sh
Michael Blocksome
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20130102/e537c5be/attachment.html>
More information about the llvm-bgq-discuss
