[Llvm-bgq-discuss] cnk syscalls
Jeff Hammond
jhammond at alcf.anl.gov
Wed Jan 2 12:31:42 CST 2013
My guess is that this is a problem with inline assembly. Is it
necessary to compile the whole project with LLVM or can you wrap the
SPI calls that use inline assembly in source that you can compile with
GCC?
I'm sure Hal will be able to give you a real solution in the near future.
Jeff
On Wed, Jan 2, 2013 at 12:17 PM, Michael Blocksome <blocksom at us.ibm.com> wrote:
> All,
> I've encountered an ICE with clang built from the recent updates (thanks!)
> when I attempt to use certain CNK syscalls. Has anyone else seen this? Is
> there a workaround?
> Here's my code and the clang output:
> .../test> cat personality_ice.cc
> #include <kernel/location.h>
> int main ()
> Personality_t personality;
> Kernel_GetPersonality(&personality, sizeof(Personality_t));
> return 0;
> .../test> /bghome/blocksom/development/llvm/bgclang++ -ferror-limit=10
> -I../include -I /bgsys/drivers/ppcfloor -I
> /bgsys/drivers/ppcfloor/spi/include -I
> /bgsys/drivers/ppcfloor/spi/include/kernel/cnk -std=c++11 -stdlib=libc++
> -fno-exceptions -v -c personality_ice.cc -o personality_ice.o
> clang version 3.3 (trunk 170456)
> Target: powerpc64-bgq-linux
> Thread model: posix
> "/bghome/blocksom/development/llvm/install/bin/clang" -cc1 -triple
> powerpc64-bgq-linux -S -disable-free -main-file-name personality_ice.cc
> -static-define -mrelocation-model static -mdisable-fp-elim -fmath-errno
> -ffp-contract=fast -mconstructor-aliases -target-cpu a2q
> -target-linker-version 2.20.51.0.2 -momit-leaf-frame-pointer -v
> -coverage-file /tmp/personality_ice-m3wqVS.s -resource-dir
> /bghome/blocksom/development/llvm/install/bin/../lib/clang/3.3 -I ../include
> -I /bgsys/drivers/ppcfloor -I /bgsys/drivers/ppcfloor/spi/include -I
> /bgsys/drivers/ppcfloor/spi/include/kernel/cnk -fmodule-cache-path
> /var/tmp/clang-module-cache -internal-isystem /usr/include/c++/v1
> -internal-isystem /usr/local/include -internal-isystem
> /bghome/blocksom/development/llvm/install/bin/../lib/clang/3.3/include
> -internal-externc-isystem /include -internal-externc-isystem /usr/include
> -std=c++11 -fdeprecated-macro -fno-dwarf-directory-asm
> -fdebug-compilation-dir /bghome/blocksom/development/boost-pami/next/test
> -ferror-limit 10 -fmessage-length 231 -mstackrealign -fno-signed-char
> -fobjc-runtime=gcc -fdiagnostics-show-option -fcolor-diagnostics -isystem
> /bghome/blocksom/development/llvm/install/libc++/include -isystem
> /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/include/c++/4.4.6
> -isystem
> /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/include/c++/4.4.6/powerpc64-bgq-linux
> -isystem /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/sys-include
> -mllvm -enable-misched -mllvm -enable-aa-sched-mi -mllvm -ilp-window=0 -o
> /tmp/personality_ice-m3wqVS.s -x c++ personality_ice.cc
> clang -cc1 version 3.3 based upon LLVM 3.3svn default target
> powerpc64-unknown-linux-gnu
> ignoring nonexistent directory "/usr/include/c++/v1"
> ignoring nonexistent directory "/include"
> #include "..." search starts here:
> #include <...> search starts here:
> ../include
> /usr/local/include
> /usr/include
> End of search list.
> Instruction uses an allocated register
> UNREACHABLE executed at
> /bghome/blocksom/development/llvm/src/lib/CodeGen/RegAllocFast.cpp:351!
> 0 clang 0x0000000011f55b1c
> 1 clang 0x0000000011f56924
> 2 0x00000fff962e0418 __kernel_sigtramp_rt64 + 0
> 3 libc.so.6 0x00000080dbd86ef8 abort + 18446744073708064168
> 4 clang 0x0000000011f38df4 llvm::llvm_unreachable_internal(char const*,
> char const*, unsigned int) + 18446744073696340212
> 5 clang 0x00000000118fa8c4
> 6 clang 0x00000000118fb77c
> 7 clang 0x000000001189498c
> llvm::MachineFunctionPass::runOnFunction(llvm::Function&) +
> 18446744073689552652
> 8 clang 0x0000000011edaa98
> llvm::FPPassManager::runOnFunction(llvm::Function&) + 18446744073695968280
> 9 clang 0x0000000011edabdc
> llvm::FPPassManager::runOnModule(llvm::Module&) + 18446744073695968588
> 10 clang 0x0000000011eda60c
> llvm::MPPassManager::runOnModule(llvm::Module&) + 18446744073695967132
> 11 clang 0x0000000011edbf64 llvm::PassManagerImpl::run(llvm::Module&) +
> 18446744073695973428
> 12 clang 0x0000000011edc074 llvm::PassManager::run(llvm::Module&) +
> 18446744073695973684
> 13 clang 0x000000001044851c
> clang::EmitBackendOutput(clang::DiagnosticsEngine&, clang::CodeGenOptions
> const&, clang::TargetOptions const&, clang::LangOptions const&,
> llvm::Module*, clang::BackendAction, llvm::raw_ostream*) +
> 18446744073668788412
> 14 clang 0x00000000104453f4
> 15 clang 0x00000000105db3d0 clang::ParseAST(clang::Sema&, bool, bool) +
> 18446744073670399680
> 16 clang 0x00000000102a0b50 clang::ASTFrontendAction::ExecuteAction() +
> 18446744073667099648
> 17 clang 0x0000000010443028 clang::CodeGenAction::ExecuteAction() +
> 18446744073668767224
> 18 clang 0x00000000102a1024 clang::FrontendAction::Execute() +
> 18446744073667100756
> 19 clang 0x000000001027ed64
> clang::CompilerInstance::ExecuteAction(clang::FrontendAction&) +
> 18446744073666962340
> 20 clang 0x000000001025f704
> clang::ExecuteCompilerInvocation(clang::CompilerInstance*) +
> 18446744073666839428
> 21 clang 0x0000000010255998 cc1_main(char const**, char const**, char
> const*, void*) + 18446744073666799576
> 22 clang 0x000000001025daf0 main + 18446744073666832256
> 23 libc.so.6 0x00000080dbd6bcf8
> 24 libc.so.6 0x00000080dbd6bef0 __libc_start_main + 18446744073707958816
> Stack dump:
> 0. Program arguments:
> /bghome/blocksom/development/llvm/install/bin/clang -cc1 -triple
> -isystem
> 1. <eof> parser at end of file
> 2. Code generation
> 3. Running pass 'Function Pass Manager' on module
> 'personality_ice.cc'.
> 4. Running pass 'Fast Register Allocator' on function '@main'
> clang: error: unable to execute command: Aborted (core dumped)
> clang: error: clang frontend command failed due to signal (use -v to see
> invocation)
> Thread model: posix
> clang: note: diagnostic msg: PLEASE submit a bug report to
> http://llvm.org/bugs/ and include the crash backtrace, preprocessed source,
> and associated run script.
> PLEASE ATTACH THE FOLLOWING FILES TO THE BUG REPORT:
> Preprocessed source(s) and associated run script(s) are located at:
> clang: note: diagnostic msg: /tmp/personality_ice-hApwmA.cpp
> clang: note: diagnostic msg: /tmp/personality_ice-hApwmA.sh
> Thanks,
> Michael Blocksome
> llvm-bgq-discuss mailing list
> llvm-bgq-discuss at lists.alcf.anl.gov
> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
Jeff Hammond
Argonne Leadership Computing Facility
University of Chicago Computation Institute
jhammond at alcf.anl.gov / (630) 252-5381
http://www.linkedin.com/in/jeffhammond
https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
More information about the llvm-bgq-discuss
