[Llvm-bgq-discuss] cnk syscalls
Hal Finkel
hfinkel at anl.gov
Wed Jan 2 13:14:59 CST 2013
----- Original Message -----
> From: "Michael Blocksome" <blocksom at us.ibm.com>
> To: llvm-bgq-discuss at lists.alcf.anl.gov
> Sent: Wednesday, January 2, 2013 12:17:37 PM
> Subject: [Llvm-bgq-discuss] cnk syscalls
> All,
> I've encountered an ICE with clang built from the recent updates
> (thanks!) when I attempt to use certain CNK syscalls. Has anyone
> else seen this? Is there a workaround?
Interesting, thanks! I'll get this fixed. I don't have a better workaround than what Jeff suggested (compile this file with gcc).
-Hal
> Here's my code and the clang output:
> .../test> cat personality_ice.cc
> #include <kernel/location.h>
> int main ()
> Personality_t personality;
> Kernel_GetPersonality(&personality, sizeof(Personality_t));
> return 0;
> .../test> /bghome/blocksom/development/llvm/bgclang++
> -ferror-limit=10 -I../include -I /bgsys/drivers/ppcfloor -I
> /bgsys/drivers/ppcfloor/spi/include -I
> /bgsys/drivers/ppcfloor/spi/include/kernel/cnk -std=c++11
> -stdlib=libc++ -fno-exceptions -v -c personality_ice.cc -o
> personality_ice.o
> clang version 3.3 (trunk 170456)
> Target: powerpc64-bgq-linux
> Thread model: posix
> "/bghome/blocksom/development/llvm/install/bin/clang" -cc1 -triple
> powerpc64-bgq-linux -S -disable-free -main-file-name
> personality_ice.cc -static-define -mrelocation-model static
> -mdisable-fp-elim -fmath-errno -ffp-contract=fast
> -mconstructor-aliases -target-cpu a2q -target-linker-version
> 2.20.51.0.2 -momit-leaf-frame-pointer -v -coverage-file
> /tmp/personality_ice-m3wqVS.s -resource-dir
> /bghome/blocksom/development/llvm/install/bin/../lib/clang/3.3 -I
> /bgsys/drivers/ppcfloor/spi/include/kernel/cnk -fmodule-cache-path
> /var/tmp/clang-module-cache -internal-isystem /usr/include/c++/v1
> -internal-isystem /usr/local/include -internal-isystem
> /bghome/blocksom/development/llvm/install/bin/../lib/clang/3.3/include
> -internal-externc-isystem /include -internal-externc-isystem
> /usr/include -std=c++11 -fdeprecated-macro -fno-dwarf-directory-asm
> -fdebug-compilation-dir
> /bghome/blocksom/development/boost-pami/next/test -ferror-limit 10
> -fmessage-length 231 -mstackrealign -fno-signed-char
> -fobjc-runtime=gcc -fdiagnostics-show-option -fcolor-diagnostics
> -isystem /bghome/blocksom/development/llvm/install/libc++/include
> -isystem
> /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/include/c++/4.4.6
> -isystem
> /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/include/c++/4.4.6/powerpc64-bgq-linux
> -isystem
> /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/sys-include
> -mllvm -enable-misched -mllvm -enable-aa-sched-mi -mllvm
> -ilp-window=0 -o /tmp/personality_ice-m3wqVS.s -x c++
> personality_ice.cc
> clang -cc1 version 3.3 based upon LLVM 3.3svn default target
> powerpc64-unknown-linux-gnu
> ignoring nonexistent directory "/usr/include/c++/v1"
> ignoring nonexistent directory "/include"
> #include "..." search starts here:
> #include <...> search starts here:
> ../include
> /usr/local/include
> /usr/include
> End of search list.
> Instruction uses an allocated register
> UNREACHABLE executed at
> /bghome/blocksom/development/llvm/src/lib/CodeGen/RegAllocFast.cpp:351!
> 0 clang 0x0000000011f55b1c
> 1 clang 0x0000000011f56924
> 2 0x00000fff962e0418 __kernel_sigtramp_rt64 + 0
> 3 libc.so.6 0x00000080dbd86ef8 abort + 18446744073708064168
> 4 clang 0x0000000011f38df4 llvm::llvm_unreachable_internal(char
> const*, char const*, unsigned int) + 18446744073696340212
> 5 clang 0x00000000118fa8c4
> 6 clang 0x00000000118fb77c
> 7 clang 0x000000001189498c
> llvm::MachineFunctionPass::runOnFunction(llvm::Function&) +
> 18446744073689552652
> 8 clang 0x0000000011edaa98
> llvm::FPPassManager::runOnFunction(llvm::Function&) +
> 18446744073695968280
> 9 clang 0x0000000011edabdc
> llvm::FPPassManager::runOnModule(llvm::Module&) +
> 18446744073695968588
> 10 clang 0x0000000011eda60c
> llvm::MPPassManager::runOnModule(llvm::Module&) +
> 18446744073695967132
> 11 clang 0x0000000011edbf64 llvm::PassManagerImpl::run(llvm::Module&)
> + 18446744073695973428
> 12 clang 0x0000000011edc074 llvm::PassManager::run(llvm::Module&) +
> 18446744073695973684
> 13 clang 0x000000001044851c
> clang::EmitBackendOutput(clang::DiagnosticsEngine&,
> clang::CodeGenOptions const&, clang::TargetOptions const&,
> clang::LangOptions const&, llvm::Module*, clang::BackendAction,
> llvm::raw_ostream*) + 18446744073668788412
> 14 clang 0x00000000104453f4
> 15 clang 0x00000000105db3d0 clang::ParseAST(clang::Sema&, bool, bool)
> + 18446744073670399680
> 16 clang 0x00000000102a0b50 clang::ASTFrontendAction::ExecuteAction()
> + 18446744073667099648
> 17 clang 0x0000000010443028 clang::CodeGenAction::ExecuteAction() +
> 18446744073668767224
> 18 clang 0x00000000102a1024 clang::FrontendAction::Execute() +
> 18446744073667100756
> 19 clang 0x000000001027ed64
> clang::CompilerInstance::ExecuteAction(clang::FrontendAction&) +
> 18446744073666962340
> 20 clang 0x000000001025f704
> clang::ExecuteCompilerInvocation(clang::CompilerInstance*) +
> 18446744073666839428
> 21 clang 0x0000000010255998 cc1_main(char const**, char const**, char
> const*, void*) + 18446744073666799576
> 22 clang 0x000000001025daf0 main + 18446744073666832256
> 23 libc.so.6 0x00000080dbd6bcf8
> 24 libc.so.6 0x00000080dbd6bef0 __libc_start_main +
> 18446744073707958816
> Stack dump:
> 0. Program arguments:
> /bghome/blocksom/development/llvm/install/bin/clang -cc1 -triple
> -isystem
> -isystem
> -isystem
> personality_ice.cc
> 1. <eof> parser at end of file
> 2. Code generation
> 3. Running pass 'Function Pass Manager' on module
> 'personality_ice.cc'.
> 4. Running pass 'Fast Register Allocator' on function '@main'
> clang: error: unable to execute command: Aborted (core dumped)
> clang: error: clang frontend command failed due to signal (use -v to
> see invocation)
> Thread model: posix
> clang: note: diagnostic msg: PLEASE submit a bug report to
> http://llvm.org/bugs/ and include the crash backtrace, preprocessed
> source, and associated run script.
> PLEASE ATTACH THE FOLLOWING FILES TO THE BUG REPORT:
> Preprocessed source(s) and associated run script(s) are located at:
> clang: note: diagnostic msg: /tmp/personality_ice-hApwmA.cpp
> clang: note: diagnostic msg: /tmp/personality_ice-hApwmA.sh
> Thanks,
> Michael Blocksome
> llvm-bgq-discuss mailing list
> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
Hal Finkel
Postdoctoral Appointee
Leadership Computing Facility
Argonne National Laboratory
More information about the llvm-bgq-discuss
