[Llvm-bgq-discuss] linker errors with llvm/current/bin/bgclang++
Hal Finkel
hfinkel at anl.gov
Sat Jan 19 19:52:00 CST 2013
Geoffrey,
In general, the code compiled with bgclang will not run on the login nodes. At -O3 (which enables autovectorization), bgclang will generate QPX vector instructions; those QPX instructions are not supported by the Power 7 CPU in the login node. You'll need to submit a job and run on the compute nodes.
-Hal
----- Original Message -----
> From: "Geoffrey Irving" <geoffrey.irving at gmail.com>
> To: "Hal Finkel" <hfinkel at anl.gov>
> Cc: "Geoffrey Irving" <irving at naml.us>, llvm-bgq-discuss at lists.alcf.anl.gov
> Sent: Saturday, January 19, 2013 6:17:56 PM
> Subject: Re: [Llvm-bgq-discuss] linker errors with llvm/current/bin/bgclang++
> No, this was on a login node. Am I correct that compiling and quick
> unit tests (which are much faster than compiling) should happen on
> login nodes?
> Geoffrey
> On Jan 19, 2013, at 3:57 PM, Hal Finkel <hfinkel at anl.gov> wrote:
> > Geoffrey,
> > You're running on the compute nodes, right? Not the login nodes?
> > -Hal
> >> From: "Geoffrey Irving" <irving at naml.us>
> >> Cc: llvm-bgq-discuss at lists.alcf.anl.gov
> >> Sent: Friday, January 18, 2013 9:35:18 PM
> >> Cool, that gets me through linking and unit tests in debug mode
> >> and
> >> optimized with -O2. However, I get an illegal instruction in some
> >> static initialization code if I use -O3. I'll see how easy it is
> >> to
> >> reduce my test case.
> >> In any case, progress!
> >> Thanks,
> >> Geoffrey
> >> On Fri, Jan 18, 2013 at 7:18 PM, Hal Finkel <hfinkel at anl.gov>
> >> wrote:
> >>> Geoffrey,
> >>> I believe this bug has been fixed in trunk; I'll updated our
> >>> install next week. In the mean time, try building with
> >>> -mcmodel=small
> >>> -Hal
> >>>> To: llvm-bgq-discuss at lists.alcf.anl.gov
> >>>> Sent: Friday, January 18, 2013 9:10:59 PM
> >>>> Subject: [Llvm-bgq-discuss] linker errors with
> >>>> I'm trying to get my C++11 app running on vesta. Compiling with
> >>>> clang
> >>>> gives me the following linker errors (summarized below, with
> >>>> full
> >>>> build output attached):
> >>>> /home/projects/llvm/current/bin/bgclang++ -o
> >>>> build/powerpc/release/core/array/RawArray.os -c
> >>>> -U__GXX_EXPERIMENTAL_CXX0X__ -O3 -funroll-loops -Wall
> >>>> -Winit-self
> >>>> -Woverloaded-virtual -Wsign-compare -fno-strict-aliasing
> >>>> -std=c++0x
> >>>> -Werror -Wno-array-bounds -Wno-unknown-pragmas -fPIC
> >>>> -DOTHER_PYTHON
> >>>> -DNDEBUG -DOTHER_THREAD_SAFE=1 -DBOOST_EXCEPTION_DISABLE
> >>>> -DBUILDING_other_core -I/usr/include/python2.6
> >>>> -I/home/irving/.local/lib/python2.6/site-packages/numpy/core/include
> >>>> -I/usr/local/include -Ibuild/include
> >>>> -I/home/irving/download/boost_1_52_0 core/array/RawArray.cpp
> >>>> ...MANY OTHER COMPILE COMMANDS...
> >>>> build/powerpc/release/core/libother_core.so -shared
> >>>> -Wl,-rpath=/gpfs/vesta_home/irving/otherlab/other/install/release/lib
> >>>> ...MANY_OTHER_OBJECT_FILES... -L/usr/lib64 -L/usr/local/lib
> >>>> -Linstall/release/lib -lpython2.6
> >>>> /bgsys/drivers/ppcfloor/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/bin/ld:
> >>>> build/powerpc/release/core/array/RawArray.os(.text+0x63e):
> >>>> unresolvable R_PPC64_TOC16_HA relocation against symbol
> >>>> `_ZTVSt9bad_alloc@@GLIBCXX_3.4'
> >>>> build/powerpc/release/core/array/RawArray.os(.text+0x642):
> >>>> unresolvable R_PPC64_TOC16_LO relocation against symbol
> >>>> build/powerpc/release/core/array/RawArray.os(.text+0x652):
> >>>> `_ZTISt9bad_alloc@@GLIBCXX_3.4'
> >>>> build/powerpc/release/core/array/RawArray.os(.text+0x656):
> >>>> final link failed: Nonrepresentable section on output
> >>>> clang: error: linker command failed with exit code 1 (use -v to
> >>>> see
> >>>> invocation)
> >>>> scons: *** [build/powerpc/release/core/libother_core.so] Error 1
> >>>> Any ideas what might be going wrong? A google search turned up
> >>>> many
> >>>> similar bugs in the past, but I haven't found a specific
> >>>> reference.
> >>>> Notes:
> >>>> 1. The only library I'm linking to is Python.
> >>>> 2. I needed to undef __GXX_EXPERIMENTAL_CXX0X__ in order to get
> >>>> -std=c++0x to compile. Otherwise it complains about stuff like
> >>>> this
> >>>> (more details on request):
> >>>> /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/include/c++/4.4.6/bits/stl_pair.h:106:10:
> >>>> error: no matching function for call to 'move'
> >>>> : first(std::move(__p.first)),
> >>>> Thanks,
> >>>> Geoffrey
> >>>> _______________________________________________
> >>>> llvm-bgq-discuss mailing list
> >>>> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> >>> Hal Finkel
> >>> Postdoctoral Appointee
> >>> Leadership Computing Facility
> >>> Argonne National Laboratory
> > Hal Finkel
Hal Finkel
More information about the llvm-bgq-discuss
