[Llvm-bgq-discuss] linker errors with llvm/current/bin/bgclang++
Geoffrey Irving
irving at naml.us
Sat Jan 19 20:27:43 CST 2013
Ah, that would certainly explain it.
Next up, clang is crashing for me with the error shown below. The
full stack trace, precompiled source, and run script are at
http://naml.us/random/clang
Have you seen similar things before, or know any workarounds?
Geoffrey
vesta:pentago% cns -j 1
scons: building associated VariantDir targets: build/powerpc/release
/home/projects/llvm/current/bin/bgclang++ -o
build/powerpc/release/endgame.os -c -U__GXX_EXPERIMENTAL_CXX0X__
-mcmodel=small -O2 -Wall -Winit-self -Woverloaded-virtual
-Wsign-compare -fno-strict-aliasing -std=c++11 -Werror
-Wno-array-bounds -Wno-unknown-pragmas -Wno-invalid-offsetof -fPIC
-DUSE_MPI -DOTHER_PYTHON -DNDEBUG -DOTHER_THREAD_SAFE=1
-DBOOST_EXCEPTION_DISABLE -DBUILDING_pentago_core
-I/bgsys/drivers/V1R1M2/ppc64/comm/sys/include
-I/bgsys/drivers/V1R1M2/ppc64/spi/include
-I/bgsys/drivers/V1R1M2/ppc64/spi/include/kernel/cnk
-I/bgsys/drivers/V1R1M2/ppc64/comm/gcc/include
-I/usr/include/python2.6
-I/home/irving/.local/lib/python2.6/site-packages/numpy/core/include
-I/home/irving/include -I/usr/local/include -Ibuild/include
-Ibuild/powerpc/release -I. -I/home/irving/download/boost_1_52_0
endgame.cpp
clang: /gpfs/vesta_home/hfinkel/src/llvm-trunk/tools/clang/lib/Sema/SemaTemplateInstantiate.cpp:2682:
llvm::PointerUnion<clang::Decl*,
clang::LocalInstantiationScope::DeclArgumentPack*>*
clang::LocalInstantiationScope::findInstantiationOf(const
clang::Decl*): Assertion `isa<LabelDecl>(D) && "declaration not
instantiated in this scope"' failed.
On Sat, Jan 19, 2013 at 5:52 PM, Hal Finkel <hfinkel at anl.gov> wrote:
> Geoffrey,
> In general, the code compiled with bgclang will not run on the login nodes. At -O3 (which enables autovectorization), bgclang will generate QPX vector instructions; those QPX instructions are not supported by the Power 7 CPU in the login node. You'll need to submit a job and run on the compute nodes.
> -Hal
>> From: "Geoffrey Irving" <geoffrey.irving at gmail.com>
>> To: "Hal Finkel" <hfinkel at anl.gov>
>> Cc: "Geoffrey Irving" <irving at naml.us>, llvm-bgq-discuss at lists.alcf.anl.gov
>> Sent: Saturday, January 19, 2013 6:17:56 PM
>> Subject: Re: [Llvm-bgq-discuss] linker errors with llvm/current/bin/bgclang++
>> No, this was on a login node. Am I correct that compiling and quick
>> unit tests (which are much faster than compiling) should happen on
>> login nodes?
>> Geoffrey
>> On Jan 19, 2013, at 3:57 PM, Hal Finkel <hfinkel at anl.gov> wrote:
>> > Geoffrey,
>> > You're running on the compute nodes, right? Not the login nodes?
>> > -Hal
>> >> From: "Geoffrey Irving" <irving at naml.us>
>> >> Cc: llvm-bgq-discuss at lists.alcf.anl.gov
>> >> Sent: Friday, January 18, 2013 9:35:18 PM
>> >> Cool, that gets me through linking and unit tests in debug mode
>> >> and
>> >> optimized with -O2. However, I get an illegal instruction in some
>> >> static initialization code if I use -O3. I'll see how easy it is
>> >> to
>> >> reduce my test case.
>> >> In any case, progress!
>> >> Thanks,
>> >> Geoffrey
>> >> On Fri, Jan 18, 2013 at 7:18 PM, Hal Finkel <hfinkel at anl.gov>
>> >> wrote:
>> >>> Geoffrey,
>> >>> I believe this bug has been fixed in trunk; I'll updated our
>> >>> install next week. In the mean time, try building with
>> >>> -mcmodel=small
>> >>> -Hal
>> >>>> To: llvm-bgq-discuss at lists.alcf.anl.gov
>> >>>> Sent: Friday, January 18, 2013 9:10:59 PM
>> >>>> Subject: [Llvm-bgq-discuss] linker errors with
>> >>>> I'm trying to get my C++11 app running on vesta. Compiling with
>> >>>> clang
>> >>>> gives me the following linker errors (summarized below, with
>> >>>> full
>> >>>> build output attached):
>> >>>> build/powerpc/release/core/array/RawArray.os -c
>> >>>> -U__GXX_EXPERIMENTAL_CXX0X__ -O3 -funroll-loops -Wall
>> >>>> -Winit-self
>> >>>> -Woverloaded-virtual -Wsign-compare -fno-strict-aliasing
>> >>>> -std=c++0x
>> >>>> -Werror -Wno-array-bounds -Wno-unknown-pragmas -fPIC
>> >>>> -DOTHER_PYTHON
>> >>>> -DNDEBUG -DOTHER_THREAD_SAFE=1 -DBOOST_EXCEPTION_DISABLE
>> >>>> -DBUILDING_other_core -I/usr/include/python2.6
>> >>>> -I/home/irving/download/boost_1_52_0 core/array/RawArray.cpp
>> >>>> ...MANY OTHER COMPILE COMMANDS...
>> >>>> build/powerpc/release/core/libother_core.so -shared
>> >>>> -Wl,-rpath=/gpfs/vesta_home/irving/otherlab/other/install/release/lib
>> >>>> ...MANY_OTHER_OBJECT_FILES... -L/usr/lib64 -L/usr/local/lib
>> >>>> -Linstall/release/lib -lpython2.6
>> >>>> /bgsys/drivers/ppcfloor/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/bin/ld:
>> >>>> build/powerpc/release/core/array/RawArray.os(.text+0x63e):
>> >>>> unresolvable R_PPC64_TOC16_HA relocation against symbol
>> >>>> `_ZTVSt9bad_alloc@@GLIBCXX_3.4'
>> >>>> build/powerpc/release/core/array/RawArray.os(.text+0x642):
>> >>>> unresolvable R_PPC64_TOC16_LO relocation against symbol
>> >>>> build/powerpc/release/core/array/RawArray.os(.text+0x652):
>> >>>> `_ZTISt9bad_alloc@@GLIBCXX_3.4'
>> >>>> build/powerpc/release/core/array/RawArray.os(.text+0x656):
>> >>>> final link failed: Nonrepresentable section on output
>> >>>> clang: error: linker command failed with exit code 1 (use -v to
>> >>>> see
>> >>>> invocation)
>> >>>> scons: *** [build/powerpc/release/core/libother_core.so] Error 1
>> >>>> Any ideas what might be going wrong? A google search turned up
>> >>>> many
>> >>>> similar bugs in the past, but I haven't found a specific
>> >>>> reference.
>> >>>> Notes:
>> >>>> 1. The only library I'm linking to is Python.
>> >>>> 2. I needed to undef __GXX_EXPERIMENTAL_CXX0X__ in order to get
>> >>>> -std=c++0x to compile. Otherwise it complains about stuff like
>> >>>> this
>> >>>> (more details on request):
>> >>>> /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/include/c++/4.4.6/bits/stl_pair.h:106:10:
>> >>>> error: no matching function for call to 'move'
>> >>>> : first(std::move(__p.first)),
>> >>>> Thanks,
>> >>>> Geoffrey
>> >>>> _______________________________________________
>> >>>> llvm-bgq-discuss mailing list
>> >>>> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
>> >>> Hal Finkel
>> >>> Postdoctoral Appointee
>> >>> Leadership Computing Facility
>> >>> Argonne National Laboratory
>> > Hal Finkel
> Hal Finkel
More information about the llvm-bgq-discuss
