[Llvm-bgq-discuss] linker errors with llvm/current/bin/bgclang++
Hal Finkel
hfinkel at anl.gov
Sat Jan 19 21:34:41 CST 2013
Geoffrey,
I've not seen that before. I'll rebase our local version next week; if it is still a problem after that I'll file a bug report upstream.
Thanks again,
Hal
----- Original Message -----
> From: "Geoffrey Irving" <irving at naml.us>
> To: "Hal Finkel" <hfinkel at anl.gov>
> Cc: llvm-bgq-discuss at lists.alcf.anl.gov
> Sent: Saturday, January 19, 2013 8:27:43 PM
> Subject: Re: [Llvm-bgq-discuss] linker errors with llvm/current/bin/bgclang++
> Ah, that would certainly explain it.
> Next up, clang is crashing for me with the error shown below. The
> full stack trace, precompiled source, and run script are at
> http://naml.us/random/clang
> Have you seen similar things before, or know any workarounds?
> Thanks,
> Geoffrey
> vesta:pentago% cns -j 1
> scons: building associated VariantDir targets: build/powerpc/release
> /home/projects/llvm/current/bin/bgclang++ -o
> build/powerpc/release/endgame.os -c -U__GXX_EXPERIMENTAL_CXX0X__
> -mcmodel=small -O2 -Wall -Winit-self -Woverloaded-virtual
> -Wsign-compare -fno-strict-aliasing -std=c++11 -Werror
> -Wno-array-bounds -Wno-unknown-pragmas -Wno-invalid-offsetof -fPIC
> -DUSE_MPI -DOTHER_PYTHON -DNDEBUG -DOTHER_THREAD_SAFE=1
> -DBOOST_EXCEPTION_DISABLE -DBUILDING_pentago_core
> -I/bgsys/drivers/V1R1M2/ppc64/comm/sys/include
> -I/bgsys/drivers/V1R1M2/ppc64/spi/include
> -I/bgsys/drivers/V1R1M2/ppc64/spi/include/kernel/cnk
> -I/bgsys/drivers/V1R1M2/ppc64/comm/gcc/include
> -I/usr/include/python2.6
> -I/home/irving/.local/lib/python2.6/site-packages/numpy/core/include
> -I/home/irving/include -I/usr/local/include -Ibuild/include
> -Ibuild/powerpc/release -I. -I/home/irving/download/boost_1_52_0
> endgame.cpp
> clang:
> /gpfs/vesta_home/hfinkel/src/llvm-trunk/tools/clang/lib/Sema/SemaTemplateInstantiate.cpp:2682:
> llvm::PointerUnion<clang::Decl*,
> clang::LocalInstantiationScope::DeclArgumentPack*>*
> clang::LocalInstantiationScope::findInstantiationOf(const
> clang::Decl*): Assertion `isa<LabelDecl>(D) && "declaration not
> instantiated in this scope"' failed.
> On Sat, Jan 19, 2013 at 5:52 PM, Hal Finkel <hfinkel at anl.gov> wrote:
> > Geoffrey,
> > In general, the code compiled with bgclang will not run on the
> > login nodes. At -O3 (which enables autovectorization), bgclang
> > will generate QPX vector instructions; those QPX instructions are
> > not supported by the Power 7 CPU in the login node. You'll need to
> > submit a job and run on the compute nodes.
> > -Hal
> >> From: "Geoffrey Irving" <geoffrey.irving at gmail.com>
> >> Cc: "Geoffrey Irving" <irving at naml.us>,
> >> Sent: Saturday, January 19, 2013 6:17:56 PM
> >> No, this was on a login node. Am I correct that compiling and
> >> quick
> >> unit tests (which are much faster than compiling) should happen on
> >> login nodes?
> >> Geoffrey
> >> On Jan 19, 2013, at 3:57 PM, Hal Finkel <hfinkel at anl.gov> wrote:
> >> > Geoffrey,
> >> > You're running on the compute nodes, right? Not the login nodes?
> >> > -Hal
> >> >> Sent: Friday, January 18, 2013 9:35:18 PM
> >> >> Cool, that gets me through linking and unit tests in debug mode
> >> >> and
> >> >> optimized with -O2. However, I get an illegal instruction in
> >> >> some
> >> >> static initialization code if I use -O3. I'll see how easy it
> >> >> is
> >> >> to
> >> >> reduce my test case.
> >> >> In any case, progress!
> >> >> Thanks,
> >> >> Geoffrey
> >> >> On Fri, Jan 18, 2013 at 7:18 PM, Hal Finkel <hfinkel at anl.gov>
> >> >> wrote:
> >> >>> Geoffrey,
> >> >>> I believe this bug has been fixed in trunk; I'll updated our
> >> >>> install next week. In the mean time, try building with
> >> >>> -mcmodel=small
> >> >>> -Hal
> >> >>>> To: llvm-bgq-discuss at lists.alcf.anl.gov
> >> >>>> Sent: Friday, January 18, 2013 9:10:59 PM
> >> >>>> Subject: [Llvm-bgq-discuss] linker errors with
> >> >>>> I'm trying to get my C++11 app running on vesta. Compiling
> >> >>>> with
> >> >>>> clang
> >> >>>> gives me the following linker errors (summarized below, with
> >> >>>> full
> >> >>>> build output attached):
> >> >>>> build/powerpc/release/core/array/RawArray.os -c
> >> >>>> -U__GXX_EXPERIMENTAL_CXX0X__ -O3 -funroll-loops -Wall
> >> >>>> -Winit-self
> >> >>>> -Woverloaded-virtual -Wsign-compare -fno-strict-aliasing
> >> >>>> -std=c++0x
> >> >>>> -Werror -Wno-array-bounds -Wno-unknown-pragmas -fPIC
> >> >>>> -DOTHER_PYTHON
> >> >>>> -DNDEBUG -DOTHER_THREAD_SAFE=1 -DBOOST_EXCEPTION_DISABLE
> >> >>>> -DBUILDING_other_core -I/usr/include/python2.6
> >> >>>> -I/home/irving/download/boost_1_52_0 core/array/RawArray.cpp
> >> >>>> ...MANY OTHER COMPILE COMMANDS...
> >> >>>> build/powerpc/release/core/libother_core.so -shared
> >> >>>> -Wl,-rpath=/gpfs/vesta_home/irving/otherlab/other/install/release/lib
> >> >>>> ...MANY_OTHER_OBJECT_FILES... -L/usr/lib64 -L/usr/local/lib
> >> >>>> -Linstall/release/lib -lpython2.6
> >> >>>> /bgsys/drivers/ppcfloor/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/bin/ld:
> >> >>>> build/powerpc/release/core/array/RawArray.os(.text+0x63e):
> >> >>>> unresolvable R_PPC64_TOC16_HA relocation against symbol
> >> >>>> `_ZTVSt9bad_alloc@@GLIBCXX_3.4'
> >> >>>> build/powerpc/release/core/array/RawArray.os(.text+0x642):
> >> >>>> unresolvable R_PPC64_TOC16_LO relocation against symbol
> >> >>>> build/powerpc/release/core/array/RawArray.os(.text+0x652):
> >> >>>> `_ZTISt9bad_alloc@@GLIBCXX_3.4'
> >> >>>> build/powerpc/release/core/array/RawArray.os(.text+0x656):
> >> >>>> final link failed: Nonrepresentable section on output
> >> >>>> clang: error: linker command failed with exit code 1 (use -v
> >> >>>> to
> >> >>>> see
> >> >>>> invocation)
> >> >>>> scons: *** [build/powerpc/release/core/libother_core.so]
> >> >>>> Error 1
> >> >>>> Any ideas what might be going wrong? A google search turned
> >> >>>> up
> >> >>>> many
> >> >>>> similar bugs in the past, but I haven't found a specific
> >> >>>> reference.
> >> >>>> Notes:
> >> >>>> 1. The only library I'm linking to is Python.
> >> >>>> 2. I needed to undef __GXX_EXPERIMENTAL_CXX0X__ in order to
> >> >>>> get
> >> >>>> -std=c++0x to compile. Otherwise it complains about stuff
> >> >>>> like
> >> >>>> this
> >> >>>> (more details on request):
> >> >>>> /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/include/c++/4.4.6/bits/stl_pair.h:106:10:
> >> >>>> error: no matching function for call to 'move'
> >> >>>> : first(std::move(__p.first)),
> >> >>>> Thanks,
> >> >>>> Geoffrey
> >> >>>> _______________________________________________
> >> >>>> llvm-bgq-discuss mailing list
> >> >>>> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> >> >>> Hal Finkel
> >> >>> Postdoctoral Appointee
> >> >>> Leadership Computing Facility
> >> >>> Argonne National Laboratory
> >> > Hal Finkel
> > Hal Finkel
Hal Finkel
More information about the llvm-bgq-discuss
