[Llvm-bgq-discuss] linker errors with llvm/current/bin/bgclang++
Geoffrey Irving
irving at naml.us
Wed Jan 23 15:52:07 CST 2013
I'm still seeing this error. If you've already rebased, should I file
a bug upstream? I can minimize it first if that would help.
Geoffrey
On Sat, Jan 19, 2013 at 7:43 PM, Geoffrey Irving <irving at naml.us> wrote:
> Great, thanks. Let me know if you'd like me to minimize it. This
> time I'll wait a bit to see if I can avoid work.
> Geoffrey
> On Sat, Jan 19, 2013 at 7:34 PM, Hal Finkel <hfinkel at anl.gov> wrote:
>> Geoffrey,
>> I've not seen that before. I'll rebase our local version next week; if it is still a problem after that I'll file a bug report upstream.
>> Thanks again,
>> Hal
>> ----- Original Message -----
>>> From: "Geoffrey Irving" <irving at naml.us>
>>> To: "Hal Finkel" <hfinkel at anl.gov>
>>> Cc: llvm-bgq-discuss at lists.alcf.anl.gov
>>> Sent: Saturday, January 19, 2013 8:27:43 PM
>>> Subject: Re: [Llvm-bgq-discuss] linker errors with llvm/current/bin/bgclang++
>>> Ah, that would certainly explain it.
>>> Next up, clang is crashing for me with the error shown below. The
>>> full stack trace, precompiled source, and run script are at
>>> http://naml.us/random/clang
>>> Have you seen similar things before, or know any workarounds?
>>> Thanks,
>>> Geoffrey
>>> vesta:pentago% cns -j 1
>>> scons: building associated VariantDir targets: build/powerpc/release
>>> /home/projects/llvm/current/bin/bgclang++ -o
>>> build/powerpc/release/endgame.os -c -U__GXX_EXPERIMENTAL_CXX0X__
>>> -mcmodel=small -O2 -Wall -Winit-self -Woverloaded-virtual
>>> -Wsign-compare -fno-strict-aliasing -std=c++11 -Werror
>>> -Wno-array-bounds -Wno-unknown-pragmas -Wno-invalid-offsetof -fPIC
>>> -DUSE_MPI -DOTHER_PYTHON -DNDEBUG -DOTHER_THREAD_SAFE=1
>>> -DBOOST_EXCEPTION_DISABLE -DBUILDING_pentago_core
>>> -I/bgsys/drivers/V1R1M2/ppc64/comm/sys/include
>>> -I/bgsys/drivers/V1R1M2/ppc64/spi/include
>>> -I/bgsys/drivers/V1R1M2/ppc64/spi/include/kernel/cnk
>>> -I/bgsys/drivers/V1R1M2/ppc64/comm/gcc/include
>>> -I/usr/include/python2.6
>>> -I/home/irving/.local/lib/python2.6/site-packages/numpy/core/include
>>> -I/home/irving/include -I/usr/local/include -Ibuild/include
>>> -Ibuild/powerpc/release -I. -I/home/irving/download/boost_1_52_0
>>> endgame.cpp
>>> clang:
>>> /gpfs/vesta_home/hfinkel/src/llvm-trunk/tools/clang/lib/Sema/SemaTemplateInstantiate.cpp:2682:
>>> llvm::PointerUnion<clang::Decl*,
>>> clang::LocalInstantiationScope::DeclArgumentPack*>*
>>> clang::LocalInstantiationScope::findInstantiationOf(const
>>> clang::Decl*): Assertion `isa<LabelDecl>(D) && "declaration not
>>> instantiated in this scope"' failed.
>>> On Sat, Jan 19, 2013 at 5:52 PM, Hal Finkel <hfinkel at anl.gov> wrote:
>>> > Geoffrey,
>>> > In general, the code compiled with bgclang will not run on the
>>> > login nodes. At -O3 (which enables autovectorization), bgclang
>>> > will generate QPX vector instructions; those QPX instructions are
>>> > not supported by the Power 7 CPU in the login node. You'll need to
>>> > submit a job and run on the compute nodes.
>>> > -Hal
>>> >> From: "Geoffrey Irving" <geoffrey.irving at gmail.com>
>>> >> Cc: "Geoffrey Irving" <irving at naml.us>,
>>> >> Sent: Saturday, January 19, 2013 6:17:56 PM
>>> >> No, this was on a login node. Am I correct that compiling and
>>> >> quick
>>> >> unit tests (which are much faster than compiling) should happen on
>>> >> login nodes?
>>> >> Geoffrey
>>> >> On Jan 19, 2013, at 3:57 PM, Hal Finkel <hfinkel at anl.gov> wrote:
>>> >> > Geoffrey,
>>> >> > You're running on the compute nodes, right? Not the login nodes?
>>> >> > -Hal
>>> >> >> Sent: Friday, January 18, 2013 9:35:18 PM
>>> >> >> Cool, that gets me through linking and unit tests in debug mode
>>> >> >> and
>>> >> >> optimized with -O2. However, I get an illegal instruction in
>>> >> >> some
>>> >> >> static initialization code if I use -O3. I'll see how easy it
>>> >> >> is
>>> >> >> to
>>> >> >> reduce my test case.
>>> >> >> In any case, progress!
>>> >> >> Thanks,
>>> >> >> Geoffrey
>>> >> >> On Fri, Jan 18, 2013 at 7:18 PM, Hal Finkel <hfinkel at anl.gov>
>>> >> >> wrote:
>>> >> >>> Geoffrey,
>>> >> >>> I believe this bug has been fixed in trunk; I'll updated our
>>> >> >>> install next week. In the mean time, try building with
>>> >> >>> -mcmodel=small
>>> >> >>> -Hal
>>> >> >>>> To: llvm-bgq-discuss at lists.alcf.anl.gov
>>> >> >>>> Sent: Friday, January 18, 2013 9:10:59 PM
>>> >> >>>> Subject: [Llvm-bgq-discuss] linker errors with
>>> >> >>>> I'm trying to get my C++11 app running on vesta. Compiling
>>> >> >>>> with
>>> >> >>>> clang
>>> >> >>>> gives me the following linker errors (summarized below, with
>>> >> >>>> full
>>> >> >>>> build output attached):
>>> >> >>>> build/powerpc/release/core/array/RawArray.os -c
>>> >> >>>> -U__GXX_EXPERIMENTAL_CXX0X__ -O3 -funroll-loops -Wall
>>> >> >>>> -Winit-self
>>> >> >>>> -Woverloaded-virtual -Wsign-compare -fno-strict-aliasing
>>> >> >>>> -std=c++0x
>>> >> >>>> -Werror -Wno-array-bounds -Wno-unknown-pragmas -fPIC
>>> >> >>>> -DOTHER_PYTHON
>>> >> >>>> -DNDEBUG -DOTHER_THREAD_SAFE=1 -DBOOST_EXCEPTION_DISABLE
>>> >> >>>> -DBUILDING_other_core -I/usr/include/python2.6
>>> >> >>>> -I/home/irving/download/boost_1_52_0 core/array/RawArray.cpp
>>> >> >>>> ...MANY OTHER COMPILE COMMANDS...
>>> >> >>>> build/powerpc/release/core/libother_core.so -shared
>>> >> >>>> -Wl,-rpath=/gpfs/vesta_home/irving/otherlab/other/install/release/lib
>>> >> >>>> ...MANY_OTHER_OBJECT_FILES... -L/usr/lib64 -L/usr/local/lib
>>> >> >>>> -Linstall/release/lib -lpython2.6
>>> >> >>>> /bgsys/drivers/ppcfloor/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/bin/ld:
>>> >> >>>> build/powerpc/release/core/array/RawArray.os(.text+0x63e):
>>> >> >>>> unresolvable R_PPC64_TOC16_HA relocation against symbol
>>> >> >>>> `_ZTVSt9bad_alloc@@GLIBCXX_3.4'
>>> >> >>>> build/powerpc/release/core/array/RawArray.os(.text+0x642):
>>> >> >>>> unresolvable R_PPC64_TOC16_LO relocation against symbol
>>> >> >>>> build/powerpc/release/core/array/RawArray.os(.text+0x652):
>>> >> >>>> `_ZTISt9bad_alloc@@GLIBCXX_3.4'
>>> >> >>>> build/powerpc/release/core/array/RawArray.os(.text+0x656):
>>> >> >>>> final link failed: Nonrepresentable section on output
>>> >> >>>> clang: error: linker command failed with exit code 1 (use -v
>>> >> >>>> to
>>> >> >>>> see
>>> >> >>>> invocation)
>>> >> >>>> scons: *** [build/powerpc/release/core/libother_core.so]
>>> >> >>>> Error 1
>>> >> >>>> Any ideas what might be going wrong? A google search turned
>>> >> >>>> up
>>> >> >>>> many
>>> >> >>>> similar bugs in the past, but I haven't found a specific
>>> >> >>>> reference.
>>> >> >>>> Notes:
>>> >> >>>> 1. The only library I'm linking to is Python.
>>> >> >>>> 2. I needed to undef __GXX_EXPERIMENTAL_CXX0X__ in order to
>>> >> >>>> get
>>> >> >>>> -std=c++0x to compile. Otherwise it complains about stuff
>>> >> >>>> like
>>> >> >>>> this
>>> >> >>>> (more details on request):
>>> >> >>>> /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/include/c++/4.4.6/bits/stl_pair.h:106:10:
>>> >> >>>> error: no matching function for call to 'move'
>>> >> >>>> : first(std::move(__p.first)),
>>> >> >>>> Thanks,
>>> >> >>>> Geoffrey
>>> >> >>>> _______________________________________________
>>> >> >>>> llvm-bgq-discuss mailing list
>>> >> >>>> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
>>> >> >>> Hal Finkel
>>> >> >>> Postdoctoral Appointee
>>> >> >>> Leadership Computing Facility
>>> >> >>> Argonne National Laboratory
>>> >> > Hal Finkel
>>> > Hal Finkel
>> Hal Finkel
More information about the llvm-bgq-discuss
