[Llvm-bgq-discuss] linker errors with llvm/current/bin/bgclang++
Hal Finkel
hfinkel at anl.gov
Sun Jan 27 23:48:09 CST 2013
----- Original Message -----
> From: "Hal Finkel" <hfinkel at anl.gov>
> To: "Geoffrey Irving" <irving at naml.us>
> Cc: llvm-bgq-discuss at lists.alcf.anl.gov
> Sent: Thursday, January 24, 2013 8:52:42 AM
> Subject: Re: [Llvm-bgq-discuss] linker errors with llvm/current/bin/bgclang++
> > From: "Geoffrey Irving" <irving at naml.us>
> > To: "Hal Finkel" <hfinkel at anl.gov>
> > Sent: Wednesday, January 23, 2013 3:52:07 PM
> > I'm still seeing this error. If you've already rebased, should I
> > file
> > a bug upstream?
> I've not yet rebased. I hope to get to that today.
There was a bunch of prep work I had to do prior to rebasing, and I think that's now done. I'll start rebasing tomorrow, and I hope that it will be done by Tuesday. I'll send out a general e-mail when the new version is ready for testing.
-Hal
> > I can minimize it first if that would help.
> That will be helpful if filing a bug is necessary.
> Thanks again,
> Hal
> > Thanks,
> > Geoffrey
> > On Sat, Jan 19, 2013 at 7:43 PM, Geoffrey Irving <irving at naml.us>
> > wrote:
> > > Great, thanks. Let me know if you'd like me to minimize it.
> > > This
> > > time I'll wait a bit to see if I can avoid work.
> > > Geoffrey
> > > On Sat, Jan 19, 2013 at 7:34 PM, Hal Finkel <hfinkel at anl.gov>
> > > wrote:
> > >> Geoffrey,
> > >> I've not seen that before. I'll rebase our local version next
> > >> week; if it is still a problem after that I'll file a bug report
> > >> upstream.
> > >> Thanks again,
> > >> Hal
> > >>> Sent: Saturday, January 19, 2013 8:27:43 PM
> > >>> Ah, that would certainly explain it.
> > >>> Next up, clang is crashing for me with the error shown below.
> > >>> The
> > >>> full stack trace, precompiled source, and run script are at
> > >>> http://naml.us/random/clang
> > >>> Have you seen similar things before, or know any workarounds?
> > >>> Thanks,
> > >>> Geoffrey
> > >>> vesta:pentago% cns -j 1
> > >>> scons: building associated VariantDir targets:
> > >>> build/powerpc/release
> > >>> /home/projects/llvm/current/bin/bgclang++ -o
> > >>> build/powerpc/release/endgame.os -c
> > >>> -U__GXX_EXPERIMENTAL_CXX0X__
> > >>> -mcmodel=small -O2 -Wall -Winit-self -Woverloaded-virtual
> > >>> -Wsign-compare -fno-strict-aliasing -std=c++11 -Werror
> > >>> -Wno-array-bounds -Wno-unknown-pragmas -Wno-invalid-offsetof
> > >>> -fPIC
> > >>> -DUSE_MPI -DOTHER_PYTHON -DNDEBUG -DOTHER_THREAD_SAFE=1
> > >>> -DBOOST_EXCEPTION_DISABLE -DBUILDING_pentago_core
> > >>> -I/bgsys/drivers/V1R1M2/ppc64/comm/sys/include
> > >>> -I/bgsys/drivers/V1R1M2/ppc64/spi/include
> > >>> -I/bgsys/drivers/V1R1M2/ppc64/spi/include/kernel/cnk
> > >>> -I/bgsys/drivers/V1R1M2/ppc64/comm/gcc/include
> > >>> -I/usr/include/python2.6
> > >>> -I/home/irving/.local/lib/python2.6/site-packages/numpy/core/include
> > >>> -I/home/irving/include -I/usr/local/include -Ibuild/include
> > >>> -Ibuild/powerpc/release -I.
> > >>> -I/home/irving/download/boost_1_52_0
> > >>> endgame.cpp
> > >>> clang:
> > >>> /gpfs/vesta_home/hfinkel/src/llvm-trunk/tools/clang/lib/Sema/SemaTemplateInstantiate.cpp:2682:
> > >>> llvm::PointerUnion<clang::Decl*,
> > >>> clang::LocalInstantiationScope::DeclArgumentPack*>*
> > >>> clang::LocalInstantiationScope::findInstantiationOf(const
> > >>> clang::Decl*): Assertion `isa<LabelDecl>(D) && "declaration not
> > >>> instantiated in this scope"' failed.
> > >>> On Sat, Jan 19, 2013 at 5:52 PM, Hal Finkel <hfinkel at anl.gov>
> > >>> wrote:
> > >>> > Geoffrey,
> > >>> > In general, the code compiled with bgclang will not run on
> > >>> > the
> > >>> > login nodes. At -O3 (which enables autovectorization),
> > >>> > bgclang
> > >>> > will generate QPX vector instructions; those QPX instructions
> > >>> > are
> > >>> > not supported by the Power 7 CPU in the login node. You'll
> > >>> > need
> > >>> > to
> > >>> > submit a job and run on the compute nodes.
> > >>> > -Hal
> > >>> >> From: "Geoffrey Irving" <geoffrey.irving at gmail.com>
> > >>> >> Cc: "Geoffrey Irving" <irving at naml.us>,
> > >>> >> Sent: Saturday, January 19, 2013 6:17:56 PM
> > >>> >> No, this was on a login node. Am I correct that compiling
> > >>> >> and
> > >>> >> quick
> > >>> >> unit tests (which are much faster than compiling) should
> > >>> >> happen on
> > >>> >> login nodes?
> > >>> >> Geoffrey
> > >>> >> On Jan 19, 2013, at 3:57 PM, Hal Finkel <hfinkel at anl.gov>
> > >>> >> wrote:
> > >>> >> > Geoffrey,
> > >>> >> > You're running on the compute nodes, right? Not the login
> > >>> >> > nodes?
> > >>> >> > -Hal
> > >>> >> >> Sent: Friday, January 18, 2013 9:35:18 PM
> > >>> >> >> Cool, that gets me through linking and unit tests in
> > >>> >> >> debug
> > >>> >> >> mode
> > >>> >> >> and
> > >>> >> >> optimized with -O2. However, I get an illegal
> > >>> >> >> instruction
> > >>> >> >> in
> > >>> >> >> some
> > >>> >> >> static initialization code if I use -O3. I'll see how
> > >>> >> >> easy
> > >>> >> >> it
> > >>> >> >> is
> > >>> >> >> to
> > >>> >> >> reduce my test case.
> > >>> >> >> In any case, progress!
> > >>> >> >> Thanks,
> > >>> >> >> Geoffrey
> > >>> >> >> On Fri, Jan 18, 2013 at 7:18 PM, Hal Finkel
> > >>> >> >> wrote:
> > >>> >> >>> Geoffrey,
> > >>> >> >>> I believe this bug has been fixed in trunk; I'll updated
> > >>> >> >>> our
> > >>> >> >>> install next week. In the mean time, try building with
> > >>> >> >>> -mcmodel=small
> > >>> >> >>> -Hal
> > >>> >> >>>> To: llvm-bgq-discuss at lists.alcf.anl.gov
> > >>> >> >>>> Sent: Friday, January 18, 2013 9:10:59 PM
> > >>> >> >>>> Subject: [Llvm-bgq-discuss] linker errors with
> > >>> >> >>>> I'm trying to get my C++11 app running on vesta.
> > >>> >> >>>> Compiling
> > >>> >> >>>> with
> > >>> >> >>>> clang
> > >>> >> >>>> gives me the following linker errors (summarized below,
> > >>> >> >>>> with
> > >>> >> >>>> full
> > >>> >> >>>> build output attached):
> > >>> >> >>>> build/powerpc/release/core/array/RawArray.os -c
> > >>> >> >>>> -U__GXX_EXPERIMENTAL_CXX0X__ -O3 -funroll-loops -Wall
> > >>> >> >>>> -Winit-self
> > >>> >> >>>> -Woverloaded-virtual -Wsign-compare
> > >>> >> >>>> -std=c++0x
> > >>> >> >>>> -Werror -Wno-array-bounds -Wno-unknown-pragmas -fPIC
> > >>> >> >>>> -DOTHER_PYTHON
> > >>> >> >>>> -DBUILDING_other_core -I/usr/include/python2.6
> > >>> >> >>>> core/array/RawArray.cpp
> > >>> >> >>>> ...MANY OTHER COMPILE COMMANDS...
> > >>> >> >>>> build/powerpc/release/core/libother_core.so -shared
> > >>> >> >>>> -Wl,-rpath=/gpfs/vesta_home/irving/otherlab/other/install/release/lib
> > >>> >> >>>> ...MANY_OTHER_OBJECT_FILES... -L/usr/lib64
> > >>> >> >>>> -L/usr/local/lib
> > >>> >> >>>> -Linstall/release/lib -lpython2.6
> > >>> >> >>>> /bgsys/drivers/ppcfloor/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/bin/ld:
> > >>> >> >>>> build/powerpc/release/core/array/RawArray.os(.text+0x63e):
> > >>> >> >>>> unresolvable R_PPC64_TOC16_HA relocation against symbol
> > >>> >> >>>> `_ZTVSt9bad_alloc@@GLIBCXX_3.4'
> > >>> >> >>>> build/powerpc/release/core/array/RawArray.os(.text+0x642):
> > >>> >> >>>> unresolvable R_PPC64_TOC16_LO relocation against symbol
> > >>> >> >>>> build/powerpc/release/core/array/RawArray.os(.text+0x652):
> > >>> >> >>>> `_ZTISt9bad_alloc@@GLIBCXX_3.4'
> > >>> >> >>>> build/powerpc/release/core/array/RawArray.os(.text+0x656):
> > >>> >> >>>> final link failed: Nonrepresentable section on output
> > >>> >> >>>> clang: error: linker command failed with exit code 1
> > >>> >> >>>> (use
> > >>> >> >>>> -v
> > >>> >> >>>> to
> > >>> >> >>>> see
> > >>> >> >>>> invocation)
> > >>> >> >>>> scons: ***
> > >>> >> >>>> [build/powerpc/release/core/libother_core.so]
> > >>> >> >>>> Error 1
> > >>> >> >>>> Any ideas what might be going wrong? A google search
> > >>> >> >>>> turned
> > >>> >> >>>> up
> > >>> >> >>>> many
> > >>> >> >>>> similar bugs in the past, but I haven't found a
> > >>> >> >>>> specific
> > >>> >> >>>> reference.
> > >>> >> >>>> Notes:
> > >>> >> >>>> 1. The only library I'm linking to is Python.
> > >>> >> >>>> 2. I needed to undef __GXX_EXPERIMENTAL_CXX0X__ in
> > >>> >> >>>> order
> > >>> >> >>>> to
> > >>> >> >>>> get
> > >>> >> >>>> -std=c++0x to compile. Otherwise it complains about
> > >>> >> >>>> stuff
> > >>> >> >>>> like
> > >>> >> >>>> this
> > >>> >> >>>> (more details on request):
> > >>> >> >>>> /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/include/c++/4.4.6/bits/stl_pair.h:106:10:
> > >>> >> >>>> error: no matching function for call to 'move'
> > >>> >> >>>> : first(std::move(__p.first)),
> > >>> >> >>>> Thanks,
> > >>> >> >>>> Geoffrey
> > >>> >> >>>> _______________________________________________
> > >>> >> >>>> llvm-bgq-discuss mailing list
> > >>> >> >>>> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> > >>> >> >>> Hal Finkel
> > >>> >> >>> Postdoctoral Appointee
> > >>> >> >>> Leadership Computing Facility
> > >>> >> >>> Argonne National Laboratory
> > >>> >> > Hal Finkel
> > >>> > Hal Finkel
> > >> Hal Finkel
More information about the llvm-bgq-discuss
