[Llvm-bgq-discuss] QPX clang BGQ
Hal Finkel
hfinkel at anl.gov
Wed May 8 12:24:25 CDT 2013
Rich,
Thanks for sending this! I can confirm that there appears to be a fast-math bug (enabled by passing -ffast-math or -Ofast), and I've found some local codes that also display this anomalous behavior. Tracking this down is next on my TODO list.
-Hal
----- Original Message -----
> Folks,
> I have recently taken Hal's latest compiler updates (version
> r176829-20130309) out for a spin on a suite of loop kernels I have
> developed for checking compiler optimizations. What I found is that
> when
> using the -ffast-math option, my result checksums are very different
> from
> when I do not use -ffast-math (for all 30 loops in the suite except
> one).
> An earlier version (r176751-20130307) does not show these
> differences.
> Also, I did not see any significant performance differences across
> the
> loop suite between these compiler versions. For completeness, I also
> compared the checksums generated when the code was compiled with the
> xlc
> 12.1 compiler. The checksums for -O0 vs. -O3 -qnostrict vs. -O3
> -qstrict
> are all essentially the same. From this I concluded that something
> is
> broken in the latest version of the optimizer.
> So, if you're going to use the latest compiler version, make sure you
> check your answers.
> --Rich
> On 5/8/13 9:42 AM, "Jeff Hammond" <jhammond at alcf.anl.gov> wrote:
> >(copying LLVM discuss - you should sign up for this list)
> >Hi Ivo,
> >I don't know the answer, but if you're on BGQ, you should use Hal's
> >version of LLVM anyways because I think it has other important
> >patches, not just QPX ones.
> >Best,
> >Jeff
> >2013/5/8 Ivo Kabadshow <i.kabadshow at fz-juelich.de>:
> >> Jeff,
> >> does clang work with QPX on BGQ or do I need Hals clang version?
> >> Best
> >> Ivo
> >> Forschungszentrum Juelich GmbH
> >> 52425 Juelich
> >> Sitz der Gesellschaft: Juelich
> >> Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR B
> >> 3498
> >> Vorsitzender des Aufsichtsrats: MinDir Dr. Karl Eugen Huthmacher
> >> Geschaeftsfuehrung: Prof. Dr. Achim Bachem (Vorsitzender),
> >> Karsten Beneke (stellv. Vorsitzender), Prof. Dr.-Ing. Harald Bolt,
> >> Prof. Dr. Sebastian M. Schmidt
> >Jeff Hammond
> >Argonne Leadership Computing Facility
> >University of Chicago Computation Institute
> >jhammond at alcf.anl.gov / (630) 252-5381
> >http://www.linkedin.com/in/jeffhammond
> >https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
> >ALCF docs: http://www.alcf.anl.gov/user-guides
> >_______________________________________________
> >llvm-bgq-discuss mailing list
> >llvm-bgq-discuss at lists.alcf.anl.gov
> >https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
More information about the llvm-bgq-discuss
