[Llvm-bgq-discuss] QPX clang BGQ
Hal Finkel
hfinkel at anl.gov
Fri May 10 10:45:51 CDT 2013
Rich,
I've just finished updating your installation with a new version (r181589-20130510). The qvfnmsub bug (which I suppose was your fast-math bug) should be fixed, as well as a few others. Please run your tests again.
Thanks again,
Hal
----- Original Message -----
> Hal,
> Sounds good. Please don't hesitate to ask if you would like me to
> help by
> running loop suite tests, etc.
> Thanks,
> Rich
> On 5/10/13 1:07 AM, "Hal Finkel" <hfinkel at anl.gov> wrote:
> >Rich, et al.,
> >I've found the fast-math bug (which actually was not fast-math
> >specific*,
> >but was almost always triggered by the Newton-iteration-based QPX
> >division code that is now generated in fast-math mode). I've fixed
> >this
> >issue in my local repository, and also rebased to pick up some
> >upstream
> >bug fixes that could affect us. vesta has been updated with the new
> >version. Unfortunately, my standard testing has revealed a new
> >upstream
> >bug. I've filed a bug report (PR15952), and as soon as that is
> >fixed,
> >I'll rebase again and make a new release.
> >(*) The problem was specifically that there was an incorrect
> >optimization
> >pattern for qvfnmsub[s].
> >Thanks again,
> >Hal
> >> Rich,
> >> Thanks for sending this! I can confirm that there appears to be a
> >> fast-math bug (enabled by passing -ffast-math or -Ofast), and I've
> >> found some local codes that also display this anomalous behavior.
> >> Tracking this down is next on my TODO list.
> >> -Hal
> >> > Folks,
> >> > I have recently taken Hal's latest compiler updates (version
> >> > r176829-20130309) out for a spin on a suite of loop kernels I
> >> > have
> >> > developed for checking compiler optimizations. What I found is
> >> > that
> >> > when
> >> > using the -ffast-math option, my result checksums are very
> >> > different
> >> > from
> >> > when I do not use -ffast-math (for all 30 loops in the suite
> >> > except
> >> > one).
> >> > An earlier version (r176751-20130307) does not show these
> >> > differences.
> >> > Also, I did not see any significant performance differences
> >> > across
> >> > the
> >> > loop suite between these compiler versions. For completeness, I
> >> > also
> >> > compared the checksums generated when the code was compiled with
> >> > the
> >> > xlc
> >> > 12.1 compiler. The checksums for -O0 vs. -O3 -qnostrict vs. -O3
> >> > -qstrict
> >> > are all essentially the same. From this I concluded that
> >> > something
> >> > is
> >> > broken in the latest version of the optimizer.
> >> > So, if you're going to use the latest compiler version, make
> >> > sure
> >> > you
> >> > check your answers.
> >> > --Rich
> >> > On 5/8/13 9:42 AM, "Jeff Hammond" <jhammond at alcf.anl.gov> wrote:
> >> > >(copying LLVM discuss - you should sign up for this list)
> >> > >Hi Ivo,
> >> > >I don't know the answer, but if you're on BGQ, you should use
> >> > >Hal's
> >> > >version of LLVM anyways because I think it has other important
> >> > >patches, not just QPX ones.
> >> > >Best,
> >> > >Jeff
> >> > >2013/5/8 Ivo Kabadshow <i.kabadshow at fz-juelich.de>:
> >> > >> Jeff,
> >> > >> does clang work with QPX on BGQ or do I need Hals clang
> >> > >> version?
> >> > >> Best
> >> > >> Ivo
> >> > >> Forschungszentrum Juelich GmbH
> >> > >> 52425 Juelich
> >> > >> Sitz der Gesellschaft: Juelich
> >> > >> Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR
> >> > >> B
> >> > >> 3498
> >> > >> Vorsitzender des Aufsichtsrats: MinDir Dr. Karl Eugen
> >> > >> Huthmacher
> >> > >> Geschaeftsfuehrung: Prof. Dr. Achim Bachem (Vorsitzender),
> >> > >> Karsten Beneke (stellv. Vorsitzender), Prof. Dr.-Ing. Harald
> >> > >> Bolt,
> >> > >> Prof. Dr. Sebastian M. Schmidt
> >> > >Jeff Hammond
> >> > >Argonne Leadership Computing Facility
> >> > >University of Chicago Computation Institute
> >> > >jhammond at alcf.anl.gov / (630) 252-5381
> >> > >http://www.linkedin.com/in/jeffhammond
> >> > >https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
> >> > >ALCF docs: http://www.alcf.anl.gov/user-guides
> >> > >_______________________________________________
> >> > >llvm-bgq-discuss mailing list
> >> > >llvm-bgq-discuss at lists.alcf.anl.gov
> >> > >https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
More information about the llvm-bgq-discuss
