[Llvm-bgq-discuss] QPX clang BGQ
Hornung, Rich
hornung1 at llnl.gov
Fri May 10 10:40:11 CDT 2013
Hal,
Sounds good. Please don't hesitate to ask if you would like me to help by
running loop suite tests, etc.
Rich
On 5/10/13 1:07 AM, "Hal Finkel" <hfinkel at anl.gov> wrote:
>Rich, et al.,
>I've found the fast-math bug (which actually was not fast-math specific*,
>but was almost always triggered by the Newton-iteration-based QPX
>division code that is now generated in fast-math mode). I've fixed this
>issue in my local repository, and also rebased to pick up some upstream
>bug fixes that could affect us. vesta has been updated with the new
>version. Unfortunately, my standard testing has revealed a new upstream
>bug. I've filed a bug report (PR15952), and as soon as that is fixed,
>I'll rebase again and make a new release.
>(*) The problem was specifically that there was an incorrect optimization
>pattern for qvfnmsub[s].
>Thanks again,
>Hal
>----- Original Message -----
>> Rich,
>> Thanks for sending this! I can confirm that there appears to be a
>> fast-math bug (enabled by passing -ffast-math or -Ofast), and I've
>> found some local codes that also display this anomalous behavior.
>> Tracking this down is next on my TODO list.
>> -Hal
>> > Folks,
>> > I have recently taken Hal's latest compiler updates (version
>> > r176829-20130309) out for a spin on a suite of loop kernels I have
>> > developed for checking compiler optimizations. What I found is
>> > that
>> > when
>> > using the -ffast-math option, my result checksums are very
>> > different
>> > from
>> > when I do not use -ffast-math (for all 30 loops in the suite except
>> > one).
>> > An earlier version (r176751-20130307) does not show these
>> > differences.
>> > Also, I did not see any significant performance differences across
>> > the
>> > loop suite between these compiler versions. For completeness, I
>> > also
>> > compared the checksums generated when the code was compiled with
>> > the
>> > xlc
>> > 12.1 compiler. The checksums for -O0 vs. -O3 -qnostrict vs. -O3
>> > -qstrict
>> > are all essentially the same. From this I concluded that something
>> > is
>> > broken in the latest version of the optimizer.
>> > So, if you're going to use the latest compiler version, make sure
>> > you
>> > check your answers.
>> > --Rich
>> > On 5/8/13 9:42 AM, "Jeff Hammond" <jhammond at alcf.anl.gov> wrote:
>> > >(copying LLVM discuss - you should sign up for this list)
>> > >Hi Ivo,
>> > >I don't know the answer, but if you're on BGQ, you should use
>> > >Hal's
>> > >version of LLVM anyways because I think it has other important
>> > >patches, not just QPX ones.
>> > >Best,
>> > >Jeff
>> > >2013/5/8 Ivo Kabadshow <i.kabadshow at fz-juelich.de>:
>> > >> Jeff,
>> > >> does clang work with QPX on BGQ or do I need Hals clang
>> > >> version?
>> > >> Best
>> > >> Ivo
>> > >> Forschungszentrum Juelich GmbH
>> > >> 52425 Juelich
>> > >> Sitz der Gesellschaft: Juelich
>> > >> Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR B
>> > >> 3498
>> > >> Vorsitzender des Aufsichtsrats: MinDir Dr. Karl Eugen Huthmacher
>> > >> Geschaeftsfuehrung: Prof. Dr. Achim Bachem (Vorsitzender),
>> > >> Karsten Beneke (stellv. Vorsitzender), Prof. Dr.-Ing. Harald
>> > >> Bolt,
>> > >> Prof. Dr. Sebastian M. Schmidt
>> > >Jeff Hammond
>> > >Argonne Leadership Computing Facility
>> > >University of Chicago Computation Institute
>> > >jhammond at alcf.anl.gov / (630) 252-5381
>> > >http://www.linkedin.com/in/jeffhammond
>> > >https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
>> > >ALCF docs: http://www.alcf.anl.gov/user-guides
>> > >_______________________________________________
>> > >llvm-bgq-discuss mailing list
>> > >llvm-bgq-discuss at lists.alcf.anl.gov
>> > >https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
More information about the llvm-bgq-discuss
