[Llvm-bgq-discuss] bgclang r203443-20140309 on vesta/mira
Hal Finkel
hfinkel at anl.gov
Tue Mar 18 01:44:34 CDT 2014
A quick update:
The r203443-20140309 OpenMP runtime library has been updated. This fixes a bug where calling omp_set_num_threads(int), and several similar functions, would cause the application to segfault.
For those maintaining their own installs, updated RPMs (and SRPMs) are available on the trac page: https://trac.alcf.anl.gov/projects/llvm-bgq
Thanks again,
Hal
----- Original Message -----
> From: "Hal Finkel" <hfinkel at anl.gov>
> To: llvm-bgq-discuss at lists.alcf.anl.gov
> Sent: Monday, March 10, 2014 11:45:45 AM
> Subject: [Llvm-bgq-discuss] bgclang r203443-20140309 on vesta/mira
> Hello again,
> I've updated our bgclang install on vesta and mira to
> r203443-20140309. A fair amount has changed, here's a summary:
> - First, we pick up the last month's work of upstream development
> work. Notably, this includes a feature I developed for the PowerPC
> backend to track boolean variables in individual CR bits. This is a
> major addition, and gives some nice performance improvements for
> control-flow dominated code, but if you want to turn it off, pass
> -mno-crbits to bgclang.
> - Second, I've rebased the OpenMP runtime library, and it is now
> derived from the latest version from LLVM's repository (and this
> version can be built by clang, not just gcc, and so the runtime
> library itself is now compiled by bgclang). This new version has
> some support for the new cancellation API (which I've not tried
> myself, but if someone is curious, please feel free to try it out
> and let us know if/how it works).
> - Third, I've changed the way that libc++, which is used by
> bgclang++11, is compiled. We need to use a configuration where both
> libc++ and libstdc++ can be linked together (because of
> dependencies in the BG/Q messaging implementation). We had been
> using a mode I had hacked up myself (because there was no upstream
> support), but now there is upstream support for this configuration,
> and we've switched to using the upstream method.
> - Use of LLVM's integrated assembler is now supported (and has full
> QPX support). You can pass -fintegrated-as to bgclang to try it
> out. There should be no observable difference in the output, but
> should be a little faster (in terms of compilation time).
> For those maintaining their own installs, RPMs (and SRPMs) are
> The upstream codebase has now switched to really requiring a
> compliant C++11 compiler and standard library in order to compile
> LLVM. As a result, the bgclang packages can no longer be built with
> the system g++, and so I've packaged a 'stage 1' clang/libcxx
> configuration, based on the 3.4 release, that is now used to build
> bgclang. I've updated the installation instructions on the website,
> but in short, you'll now need to install the 'stage 1' packages as
> well.
> Thanks again,
> Hal
> Hal Finkel
> Assistant Computational Scientist
> Leadership Computing Facility
> Argonne National Laboratory
> llvm-bgq-discuss mailing list
> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
Hal Finkel
More information about the llvm-bgq-discuss
