[Llvm-bgq-discuss] total view with clang bgq
Biddiscombe, John A.
biddisco at cscs.ch
Fri May 2 01:18:19 CDT 2014
Hal
Q1: A : yes, the gcc 4.8.2 stuff works with totalview
> Oh, you're working on the I/O nodes (with your own MPI), right? So maybe
> you can't use the special files intended for use with CNK that are normally
> used by bgclang and also use total view? Are you using the bgclang wrapper
> script when you compile for the IONs?
I use the bgclang wrapper for C compilation and bgclang++ or bgclang++11 for C++, but I do not use the bgclang MPI wrappers and I setup the MPI include and link paths/flags/libs myself using a bunch of cmake settings. The mpi used on the ION is an mvapich installed as part of the default system. (I do have trouble with performance of mpi programs, so am open to further experimentation there).
$echo $CC
/gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/bin/bgclang
$ echo $CXX
/gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/bin/bgclang++11
the full verbose link command would expand out to this ....
(NB, all the stuff which is in /gpfs/bbp.cscs.ch/home/biddisco/apps/clang like the log4cxx and boost libs is/are compiled by me using the same basic setup).
clang version 3.5.0 (trunk)
Target: powerpc64-bgq-linux
Thread model: posix
Found candidate GCC installation: /bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/lib/gcc/powerpc64-bgq-linux/4.7.2
Selected GCC installation: /bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/lib/gcc/powerpc64-bgq-linux/4.7.2
Candidate multilib: .;@m64
Selected multilib: .;@m64
"/gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/r205936-20140409/binutils/bin/ld" -export-dynamic --hash-style=gnu --no-add-needed --build-id --eh-frame-hdr -m elf64ppc -dynamic-linker /lib64/ld64.so.1 -o ../../bin/hg_test_rpc /bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/powerpc64-bgq-linux/lib/crt1.o /bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/powerpc64-bgq-linux/lib/crti.o /bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/lib/gcc/powerpc64-bgq-linux/4.7.2/crtbegin.o -L/gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/r205936-20140409/libc++/lib -L/bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/powerpc64-bgq-linux/lib -L/gpfs/bbp.cscs.ch/home/biddisco/apps/clang/boost_1_55_0/lib -L/gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/r205936-20140409/sleef/lib -L/bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/lib/gcc/powerpc64-bgq-linux/4.7.2 -L/bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/lib/gcc/powerpc64-bgq-linux/4.7.2/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/lib/gcc/powerpc64-bgq-linux/4.7.2/../../../../powerpc64-bgq-linux/lib -L/bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/lib/gcc/powerpc64-bgq-linux/4.7.2/../../.. -L/gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/r205936-20140409/bin/../lib -L/lib -L/usr/lib -rpath /gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/r205936-20140409/libc++/lib -rpath /bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/powerpc64-bgq-linux/lib CMakeFiles/hg_test_rpc.dir/test_rpc.c.o ../../bin/libmercury_test.a ../../bin/libmercury_debug.a ../../bin/libna_test.a ../../bin/libmchecksum_debug.a ../../bin/libna_debug.a ../../bin/librdma_lib.a /gpfs/bbp.cscs.ch/home/biddisco/apps/clang/log4cxx-0.10.0/lib/liblog4cxx.so /gpfs/bbp.cscs.ch/home/biddisco/apps/clang/apr-1.4.8/lib/libapr-1.so /gpfs/bbp.cscs.ch/home/biddisco/apps/clang/apr-util-1.5.3/lib/libaprutil-1.so /usr/lib64/libxml2.so.2 /gpfs/bbp.cscs.ch/home/biddisco/apps/clang/boost_1_55_0/lib/libboost_program_options-clang35-mt-d-1_55.so /gpfs/bbp.cscs.ch/home/biddisco/apps/clang/boost_1_55_0/lib/libboost_system-clang35-mt-d-1_55.so /gpfs/bbp.cscs.ch/home/biddisco/apps/clang/boost_1_55_0/lib/libboost_thread-clang35-mt-d-1_55.so /gpfs/bbp.cscs.ch/home/biddisco/apps/clang/boost_1_55_0/lib/libboost_regex-clang35-mt-d-1_55.so ../../bin/libmercury_util_debug.a -lrdmacm /usr/lib64/mvapich2/lib/libmpich.so -libverbs /usr/lib64/mvapich2/lib/libopa.so /usr/lib64/mvapich2/lib/libmpl.so -lrt -lpthread -lpthread -lrt -rpath /gpfs/bbp.cscs.ch/home/biddisco/apps/clang/boost_1_55_0/lib:/gpfs/bbp.cscs.ch/home/biddisco/apps/clang/log4cxx-0.10.0/lib:/gpfs/bbp.cscs.ch/home/biddisco/apps/clang/apr-1.4.8/lib:/gpfs/bbp.cscs.ch/home/biddisco/apps/clang/apr-util-1.5.3/lib:/usr/lib64/mvapich2/lib -rpath /gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/r205936-20140409/sleef/lib --as-needed -lsleef --no-as-needed -lc++ -lstdc++ -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/lib/gcc/powerpc64-bgq-linux/4.7.2/crtend.o /bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/powerpc64-bgq-linux/lib/crtn.o
JB
More information about the llvm-bgq-discuss
