[Llvm-bgq-discuss] total view with clang bgq
Biddiscombe, John A.
biddisco at cscs.ch
Fri May 2 02:56:39 CDT 2014
Hal,
Looking at my previous email I thought it might be easier if I sent an example which uses no mpi, no boost, no other libraries
here'a a simple test, hello.cxx
#include <iostream>
int main(int argc, char **argv)
std::cout << "Hello " << std::endl;
compiled as follows. Totalview refuses to load it. (note that if I remove the -dynamic, it compiles and links correctly as a static exe as reported by 'file', but totalview won't load it either)
Thanks in advance for any clues.
JB
bbpbg2:~/bgas/clang/build/cpp$ /gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/bin/bgclang++11 -v -dynamic CMakeFiles/hello.dir/hello.cxx.o -o hello
clang version 3.5.0 (trunk)
Target: powerpc64-bgq-linux
Thread model: posix
Found candidate GCC installation: /bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/lib/gcc/powerpc64-bgq-linux/4.7.2
Selected GCC installation: /bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/lib/gcc/powerpc64-bgq-linux/4.7.2
Candidate multilib: .;@m64
Selected multilib: .;@m64
"/gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/r205936-20140409/binutils/bin/ld" -export-dynamic --hash-style=gnu --no-add-needed --build-id --eh-frame-hdr -m elf64ppc -dynamic-linker /lib64/ld64.so.1 -o hello /bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/powerpc64-bgq-linux/lib/crt1.o /bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/powerpc64-bgq-linux/lib/crti.o /bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/lib/gcc/powerpc64-bgq-linux/4.7.2/crtbegin.o -L/gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/r205936-20140409/libc++/lib -L/bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/powerpc64-bgq-linux/lib -L/gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/r205936-20140409/sleef/lib -L/bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/lib/gcc/powerpc64-bgq-linux/4.7.2 -L/bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/lib/gcc/powerpc64-bgq-linux/4.7.2/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/lib/gcc/powerpc64-bgq-linux/4.7.2/../../../../powerpc64-bgq-linux/lib -L/bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/lib/gcc/powerpc64-bgq-linux/4.7.2/../../.. -L/gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/r205936-20140409/bin/../lib -L/lib -L/usr/lib -rpath /gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/r205936-20140409/libc++/lib -rpath /bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/powerpc64-bgq-linux/lib CMakeFiles/hello.dir/hello.cxx.o -rpath /gpfs/bbp.cscs.ch/home/biddisco/apps/clang/bgclang/r205936-20140409/sleef/lib --as-needed -lsleef --no-as-needed -lc++ -lstdc++ -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/lib/gcc/powerpc64-bgq-linux/4.7.2/crtend.o /bgsys/drivers/V1R2M1/ppc64/gnu-linux-4.7.2/powerpc64-bgq-linux/lib/crtn.o
More information about the llvm-bgq-discuss
