[Llvm-bgq-discuss] clang/bgclang
Thomas Gooding
tgooding at us.ibm.com
Tue May 6 12:36:36 CDT 2014
Sounds like some debug info would help isolate the problem library, i'd
suggest enabling the dynamic loader's trace facility. Set this environment
variable:
LD_DEBUG=files,libs
or
LD_DEBUG=all
You could also use runjob's "--strace 0" option (or slurm/cobalt
equivalent) to get a system call trace, but that might be slightly too
low-level detail.
Hope that helps,
Tom
Tom Gooding
Senior Engineer / Blue Gene SW Lead / CAPI
tgooding at us.ibm.com 507-253-0747
llvm-bgq-discuss-bounces at lists.alcf.anl.gov wrote on 05/06/2014 11:11:37
AM:
> From: "Biddiscombe, John A." <biddisco at cscs.ch>
> To: "llvm-bgq-discuss at lists.alcf.anl.gov" <llvm-bgq-
> discuss at lists.alcf.anl.gov>
> Date: 05/06/2014 11:11 AM
> Subject: [Llvm-bgq-discuss] clang/bgclang
> Sent by: llvm-bgq-discuss-bounces at lists.alcf.anl.gov
> Hal,
> In my ongoing struggle to succeed despite my repeated failures, I
> have successfully compiled boost/hpx/otherstuff with just clang++
> and linked to libc++ from the c++11 toolchain. However, when I
> startup programs compiled as part of HPX, I get a segfault in some _dl
> _fixup going on during the initialization of a static path/dir
> object in boost filesystem.
> The best explanation I’ve found from stackoverflow says (http://
stackoverflow.com/questions/10578315/segmentation-fault-in-dl-runtime-resolve)
> 1. Heap corruption (overflow) or
> 2. Mismatched parts of glibc itself.
> and 2) is clearly a possibility in my case since we’re using
> libc.so.6 => /bgsys/drivers/ppcfloor/gnu-linux-4.7.2/powerpc64-bgq-
> linux/lib/libc.so.6 (0x00000fff78420000)
> which is non-standard.
> Question: Is there anything in the bgclang script that does
> important setting of any var/flag which might influence how the exes
> get linked. I see stuff in particular that sets
> BGCLANG_TARGET_INC="-Xclang -isystem -Xclang /gpfs/bbp.cscs.ch/home/
> biddisco/apps/clang/bgclang/r206161-20140414/libc++/include
> $BGCLANG_TARGET_INC"
> and also
> BGCLANG_TARGET_FLAGS="$BGCLANG_TARGET_FLAGS -L
> $BGSYS_FLOOR/$GNU_LINUX/powerpc64-bgq-linux/lib"
> and I wonder about the -Xclang items which I understand to be
> instructions to clang plugins.
> If I have my system configured as follows
> CFLAGS="-mcpu=a2"
> CXXFLAGS="-mcpu=a2 -std=c++11 -stdlib=libc++ -D_bgq_linux -I/gpfs/
> bbp.cscs.ch/home/biddisco/apps/clang/bgclang/r206161-20140414/libc+
> +/include -I/bgsys/drivers/ppcfloor"
> LDFLAGS="-dynamic -L/gpfs/bbp.cscs.ch/home/biddisco/apps/clang/
> bgclang/r206161-20140414/libc++/lib -L/bgsys/drivers/ppcfloor/gnu-
> linux-4.7.2/powerpc64-bgq-linux/lib"
> (the -D_bgq_linux is mine and used by certain cpp files to #include
stuff)
> can you imagine what might be going wrong with my build/link to
> munge my libc initialization in any way? Have I linked to the wrong
> libc/c++ stuff perhaps?
> Typically my exes come out looking like this (ldd below) as far as
> libs are used, which seems ok, but they do segfault on start which
> is really annoying me a lot (understatement).
> thanks
> JB
> bbpbg2:~/bgas/clang/build/cpp$ ldd ../hpx/bin/network_storage
> linux-vdso64.so.1 => (0x00000fff7d580000)
> libhpxd.so.0 => /gpfs/bbp.cscs.ch/home/biddisco/
> bgas/clang/build/hpx/lib/hpx/libhpxd.so.0 (0x00000fff79b00000)
> libhpx_serializationd.so.0 => /gpfs/bbp.cscs.ch/
> home/biddisco/bgas/clang/build/hpx/lib/hpx/libhpx_serializationd.so.
> 0 (0x00000fff79ac0000)
> libboost_date_time-clang35-mt-d-1_55.so.1.55.0 => /
> gpfs/bbp.cscs.ch/home/biddisco/apps/clang/boost_1_55_0/lib/
> libboost_date_time-clang35-mt-d-1_55.so.1.55.0 (0x00000fff79a90000)
> libboost_filesystem-clang35-mt-d-1_55.so.1.55.0 => /
> libboost_filesystem-clang35-mt-d-1_55.so.1.55.0 (0x00000fff79a40000)
> libboost_program_options-clang35-mt-d-1_55.so.1.55.0
> => /gpfs/bbp.cscs.ch/home/biddisco/apps/clang/boost_1_55_0/lib/
> libboost_program_options-clang35-mt-d-1_55.so.1.55.0 (0x00000fff79920000)
> libboost_regex-clang35-mt-d-1_55.so.1.55.0 => /gpfs/
> libboost_regex-clang35-mt-d-1_55.so.1.55.0 (0x00000fff79710000)
> libboost_serialization-clang35-mt-d-1_55.so.1.55.0
> libboost_serialization-clang35-mt-d-1_55.so.1.55.0 (0x00000fff79530000)
> libboost_system-clang35-mt-d-1_55.so.1.55.0 => /
> libboost_system-clang35-mt-d-1_55.so.1.55.0 (0x00000fff79510000)
> libboost_thread-clang35-mt-d-1_55.so.1.55.0 => /
> libboost_thread-clang35-mt-d-1_55.so.1.55.0 (0x00000fff794c0000)
> libboost_atomic-clang35-mt-d-1_55.so.1.55.0 => /
> libboost_atomic-clang35-mt-d-1_55.so.1.55.0 (0x00000fff794a0000)
> libboost_chrono-clang35-mt-d-1_55.so.1.55.0 => /
> libboost_chrono-clang35-mt-d-1_55.so.1.55.0 (0x00000fff79480000)
> libboost_context-clang35-mt-d-1_55.so.1.55.0 => /
> libboost_context-clang35-mt-d-1_55.so.1.55.0 (0x00000fff79460000)
> libmpich.so.3 => /usr/lib64/mvapich2/lib/
> libmpich.so.3 (0x00000fff790f0000)
> libibverbs.so.1 => /usr/lib64/libibverbs.so.1
> (0x000000808dbe0000)
> libopa.so.1 => /usr/lib64/mvapich2/lib/libopa.so.1
> (0x00000fff790a0000)
> libmpl.so.1 => /usr/lib64/mvapich2/lib/libmpl.so.1
> (0x00000080afc00000)
> librt.so.1 => /bgsys/drivers/ppcfloor/gnu-linux-4.7.
> 2/powerpc64-bgq-linux/lib/librt.so.1 (0x00000fff78f70000)
> libpthread.so.0 => /bgsys/drivers/ppcfloor/gnu-
> linux-4.7.2/powerpc64-bgq-linux/lib/libpthread.so.0 (0x00000fff78e50000)
> librdmacm.so.1 => /usr/lib64/librdmacm.so.1
> (0x000000808dc10000)
> libhwloc.so.5 => /gpfs/bbp.cscs.ch/home/biddisco/
> apps/clang/hwloc-1.8.1/lib/libhwloc.so.5 (0x00000fff78df0000)
> libdl.so.2 => /bgsys/drivers/ppcfloor/gnu-linux-4.7.
> 2/powerpc64-bgq-linux/lib/libdl.so.2 (0x00000fff78cd0000)
> libc++.so.1 => /gpfs/bbp.cscs.ch/home/biddisco/apps/
> clang/bgclang/libc++/lib/libc++.so.1 (0x00000fff78ab0000)
> libstdc++.so.6 => /bgsys/drivers/ppcfloor/gnu-
> linux-4.7.2/powerpc64-bgq-linux/lib/libstdc++.so.6 (0x00000fff78880000)
> libm.so.6 => /bgsys/drivers/ppcfloor/gnu-linux-4.7.
> 2/powerpc64-bgq-linux/lib/libm.so.6 (0x00000fff78760000)
> libgcc_s.so.1 => /bgsys/drivers/ppcfloor/gnu-
> linux-4.7.2/powerpc64-bgq-linux/lib/libgcc_s.so.1 (0x00000fff78650000)
> 2/powerpc64-bgq-linux/lib/libc.so.6 (0x00000fff78420000)
> libibumad.so.3 => /usr/lib64/libibumad.so.3
> (0x00000080a0b60000)
> /lib64/ld64.so.1 (0x0000000020a80000)
> llvm-bgq-discuss mailing list
> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20140506/a2e590c9/attachment-0001.html>
More information about the llvm-bgq-discuss
