[Llvm-bgq-discuss] bgclang r284961-stable
Hal Finkel
hfinkel at anl.gov
Fri Dec 2 09:42:36 CST 2016
Hi again,
There's now a new stable release of bgclang: r284961-stable
For those of you with your own installs, the rpms are available from http://www.mcs.anl.gov/~hfinkel/bgclang/#r284961-stable - Please note that you'll also need the stage3 rpms as well (unlike the previous stable release).
This build is now the default on ALCF's BG/Q machines.
Thanks again,
Hal
----- Original Message -----
> From: "Hal Finkel" <hfinkel at anl.gov>
> To: "llvm-bgq-discuss" <llvm-bgq-discuss at lists.alcf.anl.gov>
> Sent: Wednesday, May 4, 2016 12:24:53 AM
> Subject: [Llvm-bgq-discuss] bgclang r266865-stable
> Hi everyone,
> I've started to put together a stable release: r266865-stable. This
> build is r266865-20160420 plus the last couple of weeks of bug
> fixes. I intend to keep this build updated with bug fixes.
> Also, r268152 contained an important QPX-related correctness fix. If
> you're using any build from this year prior to that revision, please
> upgrade (the fix is in r266865-stable too).
> http://www.mcs.anl.gov/~hfinkel/bgclang/#r266865-stable
> Thanks again,
> Hal
> Hal Finkel
> Assistant Computational Scientist
> Leadership Computing Facility
> Argonne National Laboratory
> llvm-bgq-discuss mailing list
> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
Hal Finkel
Lead, Compiler Technology and Programming Languages
More information about the llvm-bgq-discuss
