[Llvm-bgq-discuss] Error With Dynamic Linking on Mira Head Node
Derek Gaston
friedmud at gmail.com
Thu Dec 29 11:27:10 CST 2016
Having trouble getting a dynamically linked executable working on
Mira/Cetus head nodes. The executable _is_ working if I submit it to the
queue.
Compiling a static executable works both on the head node and on the
compute nodes.
Is there some special environment sauce I need that will enable me to run
these executables on the head node? Obviously I don't want to run much on
the head node... but not even being able to test the executables without a
trip through the queue is problematic! For instance... "configure" scripts
kind of rely on being able to compile/run simple test programs!
My .soft is:
+mpiwrapper-bgclang-mpi3.legacy.ndebug
@default
(Note: I have also tried essentially all the other bgclang options and they
all produce the same error).
I'm trying to compile a test.c:
int main()
return 0;
My compile line is:
mpicc -o test -dynamic test.c
The error I'm seeing is:
$ ./test
ERROR: ld.so: object '/soft/buildtools/trackdeps/${LIB}/trackdeps.so' from
LD_PRELOAD cannot be preloaded: ignored.
/bgsys/source/srcV1R2M2.15270/comm/sys/buildtools/pami/common/bgq/BgqPersonality.h:102:
/bgsys/source/srcV1R2M2.15270/comm/sys/buildtools/pami/common/bgq/BgqPersonality.h<102>
Aborted (core dumped)
Getting a stack trace out of the core file gives:
(gdb) bt
#0 0x00000fff837fec40 in raise (sig=Unhandled dwarf expression opcode 0xf3
) at ../nptl/sysdeps/unix/sysv/linux/raise.c:56
#1 0x00000fff838008b8 in abort () at abort.c:90
#2 0x00000fff841a12b8 in PAMI::BgqJobPersonality::BgqJobPersonality
(this=<value optimized out>) at
#3 0x00000fff841aeff4 in PAMI::Global::Global (this=0xfff84316848) at
/bgsys/source/srcV1R2M2.15270/comm/sys/buildtools/pami/common/bgq/Global.h:110
#4 0x00000fff8419fa1c in __static_initialization_and_destruction_0 () at
/bgsys/source/srcV1R2M2.15270/comm/sys/buildtools/pami/common/bgq/BgqGlobal.cc:25
#5 global constructors keyed to BgqGlobal.cc(void) () at
/bgsys/source/srcV1R2M2.15270/comm/sys/buildtools/pami/common/bgq/BgqGlobal.cc:70
#6 0x00000fff841d2b6c in .__do_global_ctors_aux () from
/bgsys/drivers/V1R2M2/ppc64/comm/lib/libpami-gcc.so
#7 0x00000fff83f93cac in ._init () from
#8 0x00000fff8492493c in call_init (l=0xfff84a17138, argc=Unhandled dwarf
) at dl-init.c:69
#9 call_init (l=0xfff84a17138, argc=Unhandled dwarf expression opcode 0xf3
) at dl-init.c:34
#10 0x00000fff84924acc in _dl_init (main_map=0xfff84a13610, argc=Unhandled
) at dl-init.c:133
#11 0x00000fff849140bc in ._dl_start_user () from
/bgsys/drivers/V1R2M2/ppc64/gnu-linux-4.7.2/powerpc64-bgq-linux/lib/ld64.so.1
Thanks for any help!
Derek
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20161229/9277e4b3/attachment.html>
More information about the llvm-bgq-discuss
