[Llvm-bgq-discuss] mpic++11 Runtime Error on Cetus
Michael Collins
mikeliamcollins at gmail.com
Mon Jul 18 12:22:15 CDT 2016
Thanks, Patrick. I'll give it a try and report back.
On Mon, Jul 18, 2016 at 12:20 PM, Patrick E Gartung <gartung at fnal.gov>
wrote:
> Hi Michael
> I had the same problem on vesta. I had to add the envs option with
> LD_LIBRARY_PATH to the qsub command
> qsub -n 2 --mode c1 -t 120 --env
> LD_LIBRARY_PATH=/soft/compilers/gcc/4.8.4/lib/gcc/powerpc64-bgq-linux/4.8.4/:/soft/compilers/gcc/4.8.4/lib/gcc/:/soft/compilers/gcc/4.8.4/lib/gcc/powerpc64-bgq-linux/4.8.4/../../../../powerpc64-bgq-linux/lib/:$LD_LIBRARY_PATH
> From: <llvm-bgq-discuss-bounces at lists.alcf.anl.gov> on behalf of Michael
> Collins <mikeliamcollins at gmail.com>
> Date: Monday, July 18, 2016 at 12:14 PM
> To: "llvm-bgq-discuss at lists.alcf.anl.gov" <
> llvm-bgq-discuss at lists.alcf.anl.gov>
> Subject: [Llvm-bgq-discuss] mpic++11 Runtime Error on Cetus
> Hello, all.
> I'm having some trouble running my Swift/T project on Cetus. I'm compiling
> a shared library with mpic++11 under the mpiwrapper-bclang-mpi3 wrapper,
> and my program is dynamically linked to it. At runtime, I'm getting the
> following error when my program tries to load the shared library:
> stderr[1]: couldn't load file
> "/home/mlcoll/src/eq-c/tests/genmax/EQC/libeqc.so":
> /lib64/bgq/libstdc++.so.6: version `CXXABI_1.3.5' not found (required by
> /soft/compilers/bgclang/r266865-stable/libc++/lib/libc++.so.1)
> Any ideas on how to remedy this?
> Thanks,
> Mike Collins
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20160718/8ac0a899/attachment-0001.html>
More information about the llvm-bgq-discuss
