[Llvm-bgq-discuss] mpic++11 Runtime Error on Cetus
Michael Collins
mikeliamcollins at gmail.com
Mon Jul 18 12:57:54 CDT 2016
That seems to have done the trick. My program's segfault-ing, but at least
that means the library was loaded.
On Mon, Jul 18, 2016 at 12:22 PM, Michael Collins <mikeliamcollins at gmail.com
> wrote:
> Thanks, Patrick. I'll give it a try and report back.
> On Mon, Jul 18, 2016 at 12:20 PM, Patrick E Gartung <gartung at fnal.gov>
> wrote:
>> Hi Michael
>> I had the same problem on vesta. I had to add the envs option with
>> LD_LIBRARY_PATH to the qsub command
>> qsub -n 2 --mode c1 -t 120 --env
>> LD_LIBRARY_PATH=/soft/compilers/gcc/4.8.4/lib/gcc/powerpc64-bgq-linux/4.8.4/:/soft/compilers/gcc/4.8.4/lib/gcc/:/soft/compilers/gcc/4.8.4/lib/gcc/powerpc64-bgq-linux/4.8.4/../../../../powerpc64-bgq-linux/lib/:$LD_LIBRARY_PATH
>> From: <llvm-bgq-discuss-bounces at lists.alcf.anl.gov> on behalf of Michael
>> Collins <mikeliamcollins at gmail.com>
>> Date: Monday, July 18, 2016 at 12:14 PM
>> To: "llvm-bgq-discuss at lists.alcf.anl.gov" <
>> llvm-bgq-discuss at lists.alcf.anl.gov>
>> Subject: [Llvm-bgq-discuss] mpic++11 Runtime Error on Cetus
>> Hello, all.
>> I'm having some trouble running my Swift/T project on Cetus. I'm
>> compiling a shared library with mpic++11 under the mpiwrapper-bclang-mpi3
>> wrapper, and my program is dynamically linked to it. At runtime, I'm
>> getting the following error when my program tries to load the shared
>> library:
>> stderr[1]: couldn't load file
>> "/home/mlcoll/src/eq-c/tests/genmax/EQC/libeqc.so":
>> /lib64/bgq/libstdc++.so.6: version `CXXABI_1.3.5' not found (required by
>> /soft/compilers/bgclang/r266865-stable/libc++/lib/libc++.so.1)
>> Any ideas on how to remedy this?
>> Thanks,
>> Mike Collins
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20160718/e32ecc15/attachment.html>
More information about the llvm-bgq-discuss
