[Llvm-bgq-discuss] mpic++11 Runtime Error on Cetus
Patrick E Gartung
gartung at fnal.gov
Mon Jul 18 13:25:00 CDT 2016
Probably this path or something similar
/bgsys/drivers/toolchain/V1R2M4_base_4.7.2/gnu-linux-4.7.2/powerpc64-bgq-linux/lib/
From: Michael Collins <mikeliamcollins at gmail.com<mailto:mikeliamcollins at gmail.com>>
Date: Monday, July 18, 2016 at 1:11 PM
To: Patrick Gartung <gartung at fnal.gov<mailto:gartung at fnal.gov>>
Cc: "llvm-bgq-discuss at lists.alcf.anl.gov<mailto:llvm-bgq-discuss at lists.alcf.anl.gov>" <llvm-bgq-discuss at lists.alcf.anl.gov<mailto:llvm-bgq-discuss at lists.alcf.anl.gov>>
Subject: Re: [Llvm-bgq-discuss] mpic++11 Runtime Error on Cetus
OK, I'll dig around a bit and see if I can find the libstdc++.so I need.
On Mon, Jul 18, 2016 at 1:02 PM, Patrick E Gartung <gartung at fnal.gov<mailto:gartung at fnal.gov>> wrote:
My solution only worked because I compiled with gcc4.8.4 in the mpich_cpp wrapper. I think bgclang is compiled against a different libstdc++.so. This may be the cause of the segfault. You will have to determine the correct LD_LIBRARY_PATH to use with bgclang.
Date: Monday, July 18, 2016 at 12:57 PM
That seems to have done the trick. My program's segfault-ing, but at least that means the library was loaded.
On Mon, Jul 18, 2016 at 12:22 PM, Michael Collins <mikeliamcollins at gmail.com<mailto:mikeliamcollins at gmail.com>> wrote:
Thanks, Patrick. I'll give it a try and report back.
On Mon, Jul 18, 2016 at 12:20 PM, Patrick E Gartung <gartung at fnal.gov<mailto:gartung at fnal.gov>> wrote:
Hi Michael
I had the same problem on vesta. I had to add the envs option with LD_LIBRARY_PATH to the qsub command
qsub -n 2 --mode c1 -t 120 --env LD_LIBRARY_PATH=/soft/compilers/gcc/4.8.4/lib/gcc/powerpc64-bgq-linux/4.8.4/:/soft/compilers/gcc/4.8.4/lib/gcc/:/soft/compilers/gcc/4.8.4/lib/gcc/powerpc64-bgq-linux/4.8.4/../../../../powerpc64-bgq-linux/lib/:$LD_LIBRARY_PATH
From: <llvm-bgq-discuss-bounces at lists.alcf.anl.gov<mailto:llvm-bgq-discuss-bounces at lists.alcf.anl.gov>> on behalf of Michael Collins <mikeliamcollins at gmail.com<mailto:mikeliamcollins at gmail.com>>
Date: Monday, July 18, 2016 at 12:14 PM
To: "llvm-bgq-discuss at lists.alcf.anl.gov<mailto:llvm-bgq-discuss at lists.alcf.anl.gov>" <llvm-bgq-discuss at lists.alcf.anl.gov<mailto:llvm-bgq-discuss at lists.alcf.anl.gov>>
Subject: [Llvm-bgq-discuss] mpic++11 Runtime Error on Cetus
Hello, all.
I'm having some trouble running my Swift/T project on Cetus. I'm compiling a shared library with mpic++11 under the mpiwrapper-bclang-mpi3 wrapper, and my program is dynamically linked to it. At runtime, I'm getting the following error when my program tries to load the shared library:
stderr[1]: couldn't load file "/home/mlcoll/src/eq-c/tests/genmax/EQC/libeqc.so": /lib64/bgq/libstdc++.so.6: version `CXXABI_1.3.5' not found (required by /soft/compilers/bgclang/r266865-stable/libc++/lib/libc++.so.1)
Any ideas on how to remedy this?
Mike Collins
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20160718/61fd7ce7/attachment.html>
More information about the llvm-bgq-discuss
