[Llvm-bgq-discuss] bgclang r266865-stable
Hal Finkel
hfinkel at anl.gov
Wed May 4 00:24:53 CDT 2016
Hi everyone,
I've started to put together a stable release: r266865-stable. This build is r266865-20160420 plus the last couple of weeks of bug fixes. I intend to keep this build updated with bug fixes.
Also, r268152 contained an important QPX-related correctness fix. If you're using any build from this year prior to that revision, please upgrade (the fix is in r266865-stable too).
For those of you with your own installs, the rpms are available from http://www.mcs.anl.gov/~hfinkel/bgclang/#r266865-stable
This build is now the default on ALCF's BG/Q machines.
Thanks again,
Hal
Hal Finkel
Assistant Computational Scientist
Leadership Computing Facility
Argonne National Laboratory
More information about the llvm-bgq-discuss
