[Llvm-bgq-discuss] bgclang r266865-stable
Schlottke-Lakemper, Michael
m.schlottke-lakemper at aia.rwth-aachen.de
Tue May 17 03:53:54 CDT 2016
Hi Hal,
I saw that there are actually two sets of RPMs for the stable release, one designated -1 and the other -2. Am I correct in assuming that I only need the highest version (in this case -2), i.e., that the numbers designate something like patch levels?
Michael
Michael Schlottke-Lakemper
Chair of Fluid Mechanics and Institute of Aerodynamics
RWTH Aachen University
Wüllnerstraße 5a
52062 Aachen
Germany
Phone: +49 (241) 80 95188
Fax: +49 (241) 80 92257
Mail: m.schlottke-lakemper at aia.rwth-aachen.de<mailto:m.schlottke-lakemper at aia.rwth-aachen.de>
Web: http://www.aia.rwth-aachen.de
On 04 May 2016, at 07:24 , Hal Finkel <hfinkel at anl.gov<mailto:hfinkel at anl.gov>> wrote:
Hi everyone,
I've started to put together a stable release: r266865-stable. This build is r266865-20160420 plus the last couple of weeks of bug fixes. I intend to keep this build updated with bug fixes.
Also, r268152 contained an important QPX-related correctness fix. If you're using any build from this year prior to that revision, please upgrade (the fix is in r266865-stable too).
For those of you with your own installs, the rpms are available from http://www.mcs.anl.gov/~hfinkel/bgclang/#r266865-stable
This build is now the default on ALCF's BG/Q machines.
Thanks again,
Hal
Hal Finkel
Assistant Computational Scientist
Leadership Computing Facility
Argonne National Laboratory
llvm-bgq-discuss mailing list
llvm-bgq-discuss at lists.alcf.anl.gov<mailto:llvm-bgq-discuss at lists.alcf.anl.gov>
https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20160517/a746fc30/attachment.html>
More information about the llvm-bgq-discuss
