[Llvm-bgq-discuss] bgclang r266865-stable
Hal Finkel
hfinkel at anl.gov
Wed May 18 10:21:23 CDT 2016
Hi Michael,
Thanks for the ping on this. Yes, the "-2" rpms are the second patch release. You should only need those (i.e. they completely replace the "-1" rpms). I should put together a third one soon, and I should remember to send out an announcement when I do.
-Hal
----- Original Message -----
> From: "Michael Schlottke-Lakemper" <m.schlottke-lakemper at aia.rwth-aachen.de>
> To: "Hal Finkel" <hfinkel at anl.gov>
> Cc: "llvm-bgq-discuss" <llvm-bgq-discuss at lists.alcf.anl.gov>
> Sent: Tuesday, May 17, 2016 3:53:54 AM
> Subject: Re: [Llvm-bgq-discuss] bgclang r266865-stable
> Hi Hal,
> I saw that there are actually two sets of RPMs for the stable
> release, one designated -1 and the other -2. Am I correct in
> assuming that I only need the highest version (in this case -2),
> i.e., that the numbers designate something like patch levels?
> Regards,
> Michael
> Chair of Fluid Mechanics and Institute of Aerodynamics
> RWTH Aachen University
> Wüllnerstraße 5a
> 52062 Aachen
> Germany
> Phone: +49 (241) 80 95188
> Fax: +49 (241) 80 92257
> Mail: m.schlottke-lakemper at aia.rwth-aachen.de
> Web: http://www.aia.rwth-aachen.de
> On 04 May 2016, at 07:24 , Hal Finkel < hfinkel at anl.gov > wrote:
> Hi everyone,
> I've started to put together a stable release: r266865-stable. This
> build is r266865-20160420 plus the last couple of weeks of bug
> fixes. I intend to keep this build updated with bug fixes.
> Also, r268152 contained an important QPX-related correctness fix. If
> you're using any build from this year prior to that revision, please
> upgrade (the fix is in r266865-stable too).
> For those of you with your own installs, the rpms are available from
> http://www.mcs.anl.gov/~hfinkel/bgclang/#r266865-stable
> This build is now the default on ALCF's BG/Q machines.
> Thanks again,
> Hal
> Hal Finkel
> Assistant Computational Scientist
> Leadership Computing Facility
> Argonne National Laboratory
> llvm-bgq-discuss mailing list
> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
Hal Finkel
More information about the llvm-bgq-discuss
