[Llvm-bgq-discuss] bgclang r266865-stable
Schlottke-Lakemper, Michael
m.schlottke-lakemper at aia.rwth-aachen.de
Thu May 19 01:56:00 CDT 2016
Hi Hal,
Thanks for the fast confirmation.
On a further note, thanks a lot for putting up with the extra effort of providing “official” stable versions! Until now we installed the new nightly build each night and had this version as the default module on JUQEEN, as there was (at least from my vantage point) no real distinction between any of the nightlies. With the stable build available, however, this morning I switched to r266865-stable-2 as the new default module.
Michael
On 18 May 2016, at 17:21 , Hal Finkel <hfinkel at anl.gov<mailto:hfinkel at anl.gov>> wrote:
Hi Michael,
Thanks for the ping on this. Yes, the "-2" rpms are the second patch release. You should only need those (i.e. they completely replace the "-1" rpms). I should put together a third one soon, and I should remember to send out an announcement when I do.
-Hal
----- Original Message -----
From: "Michael Schlottke-Lakemper" <m.schlottke-lakemper at aia.rwth-aachen.de<mailto:m.schlottke-lakemper at aia.rwth-aachen.de>>
To: "Hal Finkel" <hfinkel at anl.gov<mailto:hfinkel at anl.gov>>
Cc: "llvm-bgq-discuss" <llvm-bgq-discuss at lists.alcf.anl.gov<mailto:llvm-bgq-discuss at lists.alcf.anl.gov>>
Sent: Tuesday, May 17, 2016 3:53:54 AM
Subject: Re: [Llvm-bgq-discuss] bgclang r266865-stable
Hi Hal,
I saw that there are actually two sets of RPMs for the stable
release, one designated -1 and the other -2. Am I correct in
assuming that I only need the highest version (in this case -2),
i.e., that the numbers designate something like patch levels?
Michael
Chair of Fluid Mechanics and Institute of Aerodynamics
RWTH Aachen University
Wüllnerstraße 5a
52062 Aachen
Germany
Phone: +49 (241) 80 95188
Fax: +49 (241) 80 92257
Mail: m.schlottke-lakemper at aia.rwth-aachen.de<mailto:m.schlottke-lakemper at aia.rwth-aachen.de>
Web: http://www.aia.rwth-aachen.de
On 04 May 2016, at 07:24 , Hal Finkel < hfinkel at anl.gov<mailto:hfinkel at anl.gov> > wrote:
Hi everyone,
I've started to put together a stable release: r266865-stable. This
build is r266865-20160420 plus the last couple of weeks of bug
fixes. I intend to keep this build updated with bug fixes.
Also, r268152 contained an important QPX-related correctness fix. If
you're using any build from this year prior to that revision, please
upgrade (the fix is in r266865-stable too).
For those of you with your own installs, the rpms are available from
http://www.mcs.anl.gov/~hfinkel/bgclang/#r266865-stable
This build is now the default on ALCF's BG/Q machines.
Thanks again,
Hal
Hal Finkel
Assistant Computational Scientist
Leadership Computing Facility
Argonne National Laboratory
llvm-bgq-discuss mailing list
https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
Hal Finkel
URL: <http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/attachments/20160519/f18fa016/attachment-0001.html>
More information about the llvm-bgq-discuss
