[Llvm-bgq-discuss] Bug when using boost::numeic_cast
Hal Finkel
hfinkel at anl.gov
Thu May 5 16:01:15 CDT 2016
Hi Christian,
I apologize for the long turn-around time on this. The latest stable version of bgclang (http://www.mcs.anl.gov/~hfinkel/bgclang/#r266865-stable) produces the correct output (and the boost case seems to print zeros without any underflow exceptions).
-Hal
----- Original Message -----
> From: "Christian Godenschwager" <christian.godenschwager at fau.de>
> To: llvm-bgq-discuss at lists.alcf.anl.gov
> Sent: Thursday, December 3, 2015 10:35:01 AM
> Subject: [Llvm-bgq-discuss] Bug when using boost::numeic_cast
> Hi everyone!
> First let me say a big thank you to all the people who have put some
> effort
> into bgclang! It is just great to have clang available on the BG/Q
> platform.
> While compiling and running our C++ code using bgclang I stumbled
> upon a
> problem using boost::numeric_cast. The code
> #include <iostream>
> #include <boost/numeric/conversion/cast.hpp>
> int main()
> long l = 0;
> int i = boost::numeric_cast<int>( l );
> std::cout << l << " " << i << std::endl;
> results in a negative underflow exception when compiling it with
> bgclang. I
> investigated a bit and the minimal example I could come up with not
> using
> boost is
> #include <iostream>
> #include <limits>
> template< typename T >
> class Dummy
> public:
> static T lowest() { return std::numeric_limits<T>::min(); }
> int main()
> std::cout << static_cast<long>( Dummy<int>::lowest() ) <<
> std::endl;
> std::cout << static_cast<long>( Dummy<int>::lowest() ) -
> static_cast<long>(1.0) << std::endl;
> Which prints
> 2147483648
> 2147483647
> but should print
> -2147483648
> -2147483649
> The problem only occurs when using bgclang++11 while bgclang++ works
> fine.
> Also removing the intermediate Dummy class or removing the second
> line in
> the main function results in correct behavior. I could reproduce the
> wrong
> behavior with versions r248407, r236977 and r232720 while r220548
> works
> fine. I tested on JUQUEEN.
> Could anyone look into that?
> All the best,
> Christian
> Dipl.-Inform. Christian Godenschwager
> Universitaet Erlangen-Nuernberg
> Lehrstuhl fuer Informatik 10 - Systemsimulation
> Cauerstraße 11
> D-91058 Erlangen
> Tel: +49 9131 85 67292
> Fax: +49 9131 85 28928
> E-Mail: christian.godenschwager at fau.de
> llvm-bgq-discuss mailing list
> https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
Hal Finkel
Assistant Computational Scientist
Leadership Computing Facility
Argonne National Laboratory
More information about the llvm-bgq-discuss
