[Llvm-bgq-discuss] bgclang r266865-stable
Hal Finkel
hfinkel at anl.gov
Thu May 26 15:10:31 CDT 2016
----- Original Message -----
> From: "Hal Finkel" <hfinkel at anl.gov>
> To: "llvm-bgq-discuss" <llvm-bgq-discuss at lists.alcf.anl.gov>
> Sent: Saturday, May 21, 2016 8:59:15 PM
> Subject: Re: [Llvm-bgq-discuss] bgclang r266865-stable
> Hi again,
> Patch release 4 for r266865-stable is now available
> (http://www.mcs.anl.gov/~hfinkel/bgclang/#r266865-stable). This is
> the current default on Vesta/Mira.
Patch release 5 is now available.
-Hal
> -Hal
> > To: "Michael Schlottke-Lakemper"
> > <m.schlottke-lakemper at aia.rwth-aachen.de>
> > Cc: "llvm-bgq-discuss" <llvm-bgq-discuss at lists.alcf.anl.gov>
> > Sent: Friday, May 20, 2016 7:32:05 AM
> > Hi everyone,
> > Patch level 3 for r266865-stable is now available.
> > -Hal
> > > From: "Michael Schlottke-Lakemper"
> > > To: "Hal Finkel" <hfinkel at anl.gov>
> > > Sent: Thursday, May 19, 2016 1:56:00 AM
> > > Hi Hal,
> > > Thanks for the fast confirmation.
> > > On a further note, thanks a lot for putting up with the extra
> > > effort
> > > of providing “official” stable versions! Until now we installed
> > > the
> > > new nightly build each night and had this version as the default
> > > module on JUQEEN, as there was (at least from my vantage point)
> > > no
> > > real distinction between any of the nightlies. With the stable
> > > build
> > > available, however, this morning I switched to r266865-stable-2
> > > as
> > > the new default module.
> > > Regards,
> > > Michael
> > > On 18 May 2016, at 17:21 , Hal Finkel < hfinkel at anl.gov > wrote:
> > > Hi Michael,
> > > Thanks for the ping on this. Yes, the "-2" rpms are the second
> > > patch
> > > release. You should only need those (i.e. they completely replace
> > > the "-1" rpms). I should put together a third one soon, and I
> > > should
> > > remember to send out an announcement when I do.
> > > -Hal
> > > From: "Michael Schlottke-Lakemper" <
> > > m.schlottke-lakemper at aia.rwth-aachen.de >
> > > To: "Hal Finkel" < hfinkel at anl.gov >
> > > Cc: "llvm-bgq-discuss" < llvm-bgq-discuss at lists.alcf.anl.gov >
> > > Sent: Tuesday, May 17, 2016 3:53:54 AM
> > > Hi Hal,
> > > I saw that there are actually two sets of RPMs for the stable
> > > release, one designated -1 and the other -2. Am I correct in
> > > assuming that I only need the highest version (in this case -2),
> > > i.e., that the numbers designate something like patch levels?
> > > Regards,
> > > Michael
> > > Chair of Fluid Mechanics and Institute of Aerodynamics
> > > RWTH Aachen University
> > > Wüllnerstraße 5a
> > > 52062 Aachen
> > > Germany
> > > Phone: +49 (241) 80 95188
> > > Fax: +49 (241) 80 92257
> > > Mail: m.schlottke-lakemper at aia.rwth-aachen.de
> > > Web: http://www.aia.rwth-aachen.de
> > > On 04 May 2016, at 07:24 , Hal Finkel < hfinkel at anl.gov > wrote:
> > > Hi everyone,
> > > I've started to put together a stable release: r266865-stable.
> > > This
> > > build is r266865-20160420 plus the last couple of weeks of bug
> > > fixes. I intend to keep this build updated with bug fixes.
> > > Also, r268152 contained an important QPX-related correctness fix.
> > > If
> > > you're using any build from this year prior to that revision,
> > > please
> > > upgrade (the fix is in r266865-stable too).
> > > For those of you with your own installs, the rpms are available
> > > from
> > > This build is now the default on ALCF's BG/Q machines.
> > > Thanks again,
> > > Hal
> > > Hal Finkel
> > > Assistant Computational Scientist
> > > Leadership Computing Facility
> > > Argonne National Laboratory
> > > _______________________________________________
> > > llvm-bgq-discuss mailing list
> > > https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> > > Hal Finkel
> > Hal Finkel
> Hal Finkel
Hal Finkel
More information about the llvm-bgq-discuss
