[Llvm-bgq-discuss] clang-4.0: error: unknown argument: '-qlanglvl=extended0x'
Jozsef Bakosi
jbakosi at lanl.gov
Fri Jan 26 13:33:53 CST 2018
Thanks, Phil,
I'm compiling the code for which I wrote the build system and I have never heard
of this flag, so it is definitely not a flag added by what I wrote. That build
system only adds to the existing flags whatever compiler is using, which is
mpic++11, a wrapper for bgclang. Grepping for qlang from `mpic++11 --help`
yields nothing and I cannot find a manual page. I'm not sure how to remove that
argument from the list.
J
On 01.26.2018 13:26, Phil Miller wrote:
> Hi Jozsef,
> That's an xlc flag to enable what c++11 support the bgq version had.
> I'm going to guess it's being added by the build system of whatever
> software you're compiling, thinking that it sees compilation on bgq and
> so needs to add it.
> That software should probably evolve to test which compiler it's
> facing, and appt the flag accordingly.
> Meanwhile, it would probably be useful for bgclang to know that flag
> and interpret it appropriately (enable c++11 support if it isn't
> already active)
> Phil
> On Jan 26, 2018 1:22 PM, "Jozsef Bakosi" <[1]jbakosi at lanl.gov> wrote:
> Hi folks,
> After
> soft add +mpiwrapper-gcc
> soft add +mpiwrapper-bgclang
> Using /soft/compilers/bgclang/mpi/bgclang/bin/mpic++11, I'm getting
> the linking
> error:
> Does anyone have an idea how to fix this?
> Thanks,
> Jozsef
> Jozsef Bakosi, Ph.D.
> Computational Physics and Methods (CCS-2)
> MS D413, Los Alamos National Laboratory
> Los Alamos, NM 87545, USA
> email: [2]jbakosi at lanl.gov
> phone: [3]505-665-0950
> fax: [4]505-665-4972
> llvm-bgq-discuss mailing list
> [5]llvm-bgq-discuss at lists.alcf.anl.gov
> [6]https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
> References
> 5. mailto:llvm-bgq-discuss at lists.alcf.anl.gov
> 6. https://lists.alcf.anl.gov/mailman/listinfo/llvm-bgq-discuss
More information about the llvm-bgq-discuss
