[Llvm-bgq-discuss] Errors when compiling LLVM with Clang for BG/P
Prentice Bisbal
prentice.bisbal at rutgers.edu
Thu Mar 14 15:08:59 CDT 2013
dear LLVM_BGQ list,
I'm trying to build LLVM with Clang for BG/P. I downloaded the patches
for the r157929-20120603 revision from
http://trac.alcf.anl.gov/projects/llvm-bgq, downloaded the corresponding
revisions of LLVM and Clang and applied the patches. I downloaded the
latest version of compiler-rt, since non of the patches modified
compiler-rt, I figured that I could use the latest version. I recognize
this may be a wrong assumption. My make eventually fails. Can someone
offer any assistance? My download/patch/make steps are shown below,
along with the warning/errors I get during the build.
Questions/comments:
1. Do I need to download a specific version of compiler-rt to match the
versions of LLVM and Clang?
2. Are there any flags I should set in my environment, or as part of the
configure command? I've seen a couple web pages that say to set
CXXFLAGS=-UPPC or CPPFLAGS=-UPPC. Since one page said CPPFLAGS, and the
other said CXXFLAGS, I'm dubious.
3. I know Hal Finkel provided new patches on the mailing list on
December 13th
http://lists.alcf.anl.gov/pipermail/llvm-bgq-discuss/2012-December/000010.html)
(but I can't get these patches to work. One of the patche files ends
prematurely, so the patch process fails.
4 Since I'm compiling for a BG/P and the development is focused on the
BG/Q, I figure these newer patches in (3) probably don't really affect
me. Right or wrong?
Thanks for your help. Build process/make errors below.
cd /scratch/prentice/build/
mkdir llvm
cd !
# down load patches
wget
http://trac.alcf.anl.gov/projects/llvm-bgq/raw-attachment/wiki/WikiStart/llvm_bgq_r157929-20120602.patch
wget
http://trac.alcf.anl.gov/projects/llvm-bgq/raw-attachment/wiki/WikiStart/clang_bgq_r157921-20120603.patch
# checkout specific versions of llvm, clang, and compiler-rt from SVN:
svn -r 157929 co http://llvm.org/svn/llvm-project/llvm/trunk llvm
cd llvm/tools/
svn -r 157921 co http://llvm.org/svn/llvm-project/cfe/trunk clang
cd ../../llvm/projects
svn co http://llvm.org/svn/llvm-project/compiler-rt/trunk compiler-rt
cd ../
# apply patches
patch -p1 < ../llvm_bgq_r157929-20120602.patch
cd tools/clang/
patch -p1 < ../../../clang_bgq_r157921-20120603.patch
# Configure and build
cd ../../
./configure \
--prefix=/usr/local/llvm_bgq-r157929 \
2>&1 | tee configure.log
make ENABLE_OPTIMIZED=1 OPTIMIZE_OPTION=-O2 EXTRA_OPTIONS=-mminimal-toc
2>&1 | tee make.log
# This produces this warning:
llvm[2]: Compiling InlineSpiller.cpp for Release+Asserts build
/scratch/prentice/build/llvm/llvm/include/llvm/ADT/PointerIntPair.h: In
member function ‘PointerTy* llvm::PointerI
ntPair<PointerTy, IntBits, IntType, PtrTraits>::getAddrOfPointer() [with
PointerTy = void*, unsigned int IntBits =
1u, IntType = bool, PtrTraits =
llvm::PointerUnionUIntTraits<llvm::VNInfo*,
llvm::SmallVector<llvm::VNInfo*, 4u>*
/scratch/prentice/build/llvm/llvm/include/llvm/ADT/PointerUnion.h:157:
instantiated from ‘PT1* llvm::PointerUnio
n<PT1, PT2>::getAddrOfPtr1() [with PT1 = llvm::VNInfo*, PT2 =
llvm::SmallVector<llvm::VNInfo*, 4u>*]’
/scratch/prentice/build/llvm/llvm/include/llvm/ADT/TinyPtrVector.h:81:
instantiated from ‘EltTy* llvm::TinyPtrVe
ctor<EltTy>::begin() [with EltTy = llvm::VNInfo*]’
InlineSpiller.cpp:382: instantiated from here
/scratch/prentice/build/llvm/llvm/include/llvm/ADT/PointerIntPair.h:102:
warning: dereferencing type-punned pointe
r will break strict-aliasing rules
In file included from MCTargetDesc/X86BaseInfo.h:20,
from X86.h:18,
from X86AsmPrinter.h:17,
from X86AsmPrinter.cpp:15:
MCTargetDesc/X86MCTargetDesc.h:105:34: error: X86GenRegisterInfo.inc: No
such file or directory
MCTargetDesc/X86MCTargetDesc.h:110:31: error: X86GenInstrInfo.inc: No
MCTargetDesc/X86MCTargetDesc.h:113:35: error: X86GenSubtargetInfo.inc:
No such file or directory
In file included from X86InstrInfo.h:18,
from X86TargetMachine.h:19,
from X86AsmPrinter.h:19,
X86RegisterInfo.h:20:34: error: X86GenRegisterInfo.inc: No such file or
directory
In file included from X86TargetMachine.h:19,
X86InstrInfo.h:23:31: error: X86GenInstrInfo.inc: No such file or directory
In file included from X86ISelLowering.h:18,
from X86TargetMachine.h:20,
X86Subtarget.h:23:35: error: X86GenSubtargetInfo.inc: No such file or
directory
MCTargetDesc/X86BaseInfo.h: In function ‘bool
llvm::X86II::isX86_64ExtendedReg(unsigned int)’:
MCTargetDesc/X86BaseInfo.h:597: error: ‘R8’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:597: error: ‘R9’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:597: error: ‘R10’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:597: error: ‘R11’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:598: error: ‘R12’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:598: error: ‘R13’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:598: error: ‘R14’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:598: error: ‘R15’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:599: error: ‘R8D’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:599: error: ‘R9D’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:599: error: ‘R10D’ is not a member of ‘llvm::X8
MCTargetDesc/X86BaseInfo.h:599: error: ‘R11D’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:600: error: ‘R12D’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:600: error: ‘R13D’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:600: error: ‘R14D’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:600: error: ‘R15D’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:601: error: ‘R8W’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:601: error: ‘R9W’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:601: error: ‘R10W’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:601: error: ‘R11W’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:602: error: ‘R12W’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:602: error: ‘R13W’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:602: error: ‘R14W’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:602: error: ‘R15W’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:603: error: ‘R8B’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:603: error: ‘R9B’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:603: error: ‘R10B’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:603: error: ‘R11B’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:604: error: ‘R12B’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:604: error: ‘R13B’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:604: error: ‘R14B’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:604: error: ‘R15B’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:605: error: ‘XMM8’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:605: error: ‘XMM9’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:605: error: ‘XMM10’ is not a member of
‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:605: error: ‘XMM11’ is not a member of
‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:606: error: ‘XMM12’ is not a member of
‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:606: error: ‘XMM13’ is not a member of
‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:606: error: ‘XMM14’ is not a member of
‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:606: error: ‘XMM15’ is not a member of
‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:607: error: ‘YMM8’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:607: error: ‘YMM9’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:607: error: ‘YMM10’ is not a member of
‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:607: error: ‘YMM11’ is not a member of
‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:608: error: ‘YMM12’ is not a member of
‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:608: error: ‘YMM13’ is not a member of
‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:608: error: ‘YMM14’ is not a member of
‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:608: error: ‘YMM15’ is not a member of
‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:609: error: ‘CR8’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:609: error: ‘CR9’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:609: error: ‘CR10’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:610: error: ‘CR12’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:610: error: ‘CR13’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:610: error: ‘CR14’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:610: error: ‘CR15’ is not a member of ‘llvm::X86’
llvm::X86II::isX86_64NonExtLowByteReg(unsigned int)’:
MCTargetDesc/X86BaseInfo.h:617: error: ‘SPL’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:617: error: ‘BPL’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:618: error: ‘SIL’ is not a member of ‘llvm::X86’
MCTargetDesc/X86BaseInfo.h:618: error: ‘DIL’ is not a member of ‘llvm::X86’
X86RegisterInfo.h: At global scope:
X86RegisterInfo.h:27: error: expected class-name before ‘{’ token
X86RegisterInfo.h:27: warning: ‘class llvm::X86RegisterInfo’ has virtual
functions but non-virtual destructor
X86InstrInfo.h:127: error: expected class-name before ‘{’ token
X86InstrInfo.h:127: warning: ‘class llvm::X86InstrInfo’ has virtual
X86Subtarget.h:42: error: expected class-name before ‘{’ token
X86Subtarget.h:308: error: ‘RegClassVector’ has not been declared
X86TargetMachine.h:46: error: invalid covariant return type for ‘virtual
const llvm::X86InstrInfo* llvm::X86Target
Machine::getInstrInfo() const’
/scratch/prentice/build/llvm/llvm/include/llvm/Target/TargetMachine.h:104:
error: overriding ‘virtual const llvm
::TargetInstrInfo* llvm::TargetMachine::getInstrInfo() const’
X86TargetMachine.h:55: error: invalid covariant return type for ‘virtual
const llvm::X86Subtarget* llvm::X86Target
Machine::getSubtargetImpl() const’
/scratch/prentice/build/llvm/llvm/include/llvm/Target/TargetMachine.h:62: error:
overriding ‘virtual const llvm:
:TargetSubtargetInfo* llvm::TargetMachine::getSubtargetImpl() const’
X86TargetMachine.h:62: error: invalid covariant return type for ‘virtual
const llvm::X86RegisterInfo* llvm::X86Tar
getMachine::getRegisterInfo() const’
/scratch/prentice/build/llvm/llvm/include/llvm/Target/TargetMachine.h:125:
::TargetRegisterInfo* llvm::TargetMachine::getRegisterInfo() const’
X86AsmPrinter.cpp: In member function ‘void
llvm::X86AsmPrinter::printLeaMemReference(const llvm::MachineInstr*, u
nsigned int, llvm::raw_ostream&, const char*)’:
X86AsmPrinter.cpp:317: error: ‘RIP’ is not a member of ‘llvm::X86’
X86AsmPrinter.cpp:337: error: ‘ESP’ is not a member of ‘llvm::X86’
In member function ‘const STC& llvm::Target
Machine::getSubtarget() const [with STC = llvm::X86Subtarget]’:
X86AsmPrinter.h:34: instantiated from here
/scratch/prentice/build/llvm/llvm/include/llvm/Target/TargetMachine.h:118:
error: invalid static_cast from type ‘c
onst llvm::TargetSubtargetInfo*’ to type ‘const llvm::X86Subtarget*’
make[3]: ***
[/scratch/prentice/build/llvm/llvm/lib/Target/X86/Release+Asserts/X86AsmPrinter.o]
Error 1
make[3]: Leaving directory
`/scratch/prentice/build/llvm/llvm/lib/Target/X86'
make[2]: *** [X86/.makeall] Error 2
make[2]: Leaving directory `/scratch/prentice/build/llvm/llvm/lib/Target'
make[1]: *** [Target/.makeall] Error 2
make[1]: Leaving directory `/scratch/prentice/build/llvm/llvm/lib'
make: *** [all] Error 1
Prentice
More information about the llvm-bgq-discuss
